Question about Acer AL1912B 19" LCD Monitor
Monitor display My monitor has started to turn on and off while using my computer. When I shutdown the computer the monitor light will go from amber the standby mode to either green or completely off. These symptoms exist even after disconnecting the monitor from the computer. I am thinking I will be needing another monitor. The frequency of these on & of episodes varies from every few seconds to once every 15-30 minutes. Any solution will be appreciated.
    Problem Solver:
  • 5 Answers
You have either a short in the cable, or your display screen(if it's CRT) is dying.
Posted on May 07, 2007
SOURCE:
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Acer AL1912B 19" LCD Monitor Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
