Question about Asko D1976 Built-in Dishwasher
New install; where to hook up old wiring/plug to ASKO
Trying to wire ASKO with standard plug from Whirlpool. Don't see black/white/green wires in ASKO. Does this thing take a special wiring harness?
  • 2 more comments
  • alan24648 Jan 01, 2009
    I do not see any "loose" wires. There are a grey wire, a white wire and 2 green& yellow wires that are plugged into an existing connector in the front. This would seem to be the right location for a connection because there is a strain reliever right next to this and I assume that the hook up is made here and the wires are then passed through the strain reliever towards the back of the machine. However, it seems like this is not the usual connection made by just twisting the wires together with one of those plastic caps.
  • alan24648 Jan 02, 2009
    I cannot get behind the front panel. Removed all screws. BUT, Called ASKO and they emailed a wiring diagram which is a little tough to read for me. So I am still at square 1+..
  • alan24648 Jan 04, 2009
    I figured it out. Have to think like a Swede. Wires go in like some speaker wires go into back of speaker. Undid screws, inserted wires, tightened down screws. Done. Thanks for doing some thinking about it. appreciate it.
  • David Robinson May 11, 2010
    What wires do you see.
    Scholar:
  • 140 Answers
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Posted on Jan 01, 2009
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I am trying to convert a three wire prong to 4 on my whirlpool dryer.
Inside the back of your dryer is a strip where the electric cord fastens on, behind a squarish panel about 5" X 5" sort-of.
There should be 3 screws/nuts in a row of the cord to hook to.
The right and the left screw/nut is HOT, for the black or red wire on a 4 wire cord. It does not matter which gets black and which gets red, they are both HOT. These wires are attached to the FLAT lugs on the plug end of the cord, NOT the "L" shaped or the round lugs.
On a four wire cord, there are also a white wire and a blue or green wire. These are both ground wires. The white wire goes to the middle screw/nut on the 3 connection bar of the machine, and the blue/green wire goes to the body of the dryer itself. (Use one of the little screws along side the opening for the wire.) The white wire goes to the "L" shaped lug on the plug, and the green/blue wire goes to the round lug of the plug.
Be blessed.
Jun 23, 2013 | Dryers
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
I need to change the 3 wire plug on my whirlpool model LE5790XS dryer to a 4 wire plug...old one is not color coded and I dont want to hook it up wrong...whats the correct way to connect this plug?
To install your 4 wire plug ,the white wire goes to the center wiring terminal on the dryer. The green ground wire attaches to the terminal cover screw outside the dryer. The red and black wires go right and left on the dryer terminal.
Nov 12, 2009 | Dryers
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Asko D1976 Built-in Dishwasher Logo
191 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
