Question about Sanyo MM-8300
What to do with a pone full oif coffee?
My phone fell in a mug of coffee and it will not turn on anymore what can i do?
Its too late to do anything youh should have took it apart and dried it out with a hair dryer let it sit over night than turned it on in the morning thats what i did when mine fell in mop water and it worked after the next day
Posted on Apr 04, 2009
All lights are blinking on coffee maker & unable to brew.
The cups only brew one mug at a time. Open and close the lid to check if that resets itself.
Otherwise, turn the machine off and on again to "reset" the function. Also check that there is enough water
Nov 12, 2013 | Keurig Coffee Makers & Espresso Machines
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
I have the B60 model. It has been wonderful from day one and then...today...I made 2 cups this morning, went back about 2:00 to make another and it was off. Hummm...so I tried to turn it on and it will...
Try the following steps to reset the processor:
1. Simultaneously press and release ?small mug? and ?medium mug?. Immediately afterward press ?menu? 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press ?menu? once. Your LCD screen should say Brew 0:00.
3. Press and hold ?medium mug?. While holding ?medium mug? press and release ?menu?. Immediately after releasing ?menu? (while still holding ?medium mug?) press ?small mug?. Release ?small mug? and ?medium mug? at the same time. This entire thing needs to be done very quickly.
4. Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back in, turn it on and follow the instructions for priming.
Jan 05, 2011 | Keurig B60 Coffee Maker
My brewer has 3 settings for dispensing coffee. Coffee cup, mug, large mug. It doesn't fill a mug or a large mug. It only goes half-way. Any suggestions how to remedy this problem?
Your problem is on the setting section of the coffee maker. Try to check if there is a visible adjuster knob or variable resistor to adjust the setting for the mug and the large mug. If there is none the adjustment is to be done by opening the system panel of your coffee maker.
Nov 02, 2010 | Keurig Coffee Makers & Espresso Machines
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
I have B30 Mini Keurig. The green power light comes on but the blue flashing light never comes on after I put the kcup and water in there. It does not brew. What could be wrong?
I also just had the same problem- the answer for me was the coffee mug. The sensor lights where you place your mug don't like certain coffee cups- in my case it was any clear mugs. First I had a clear acrylic coffee mug, then a clear glass mug, then tried regular opaque coffee mugs and it worked fine. So maybe if it's clear or somewhat transparent it might mess up the sensors. Hope that's all the problem is for you.
Aug 29, 2010 | Microwave Ovens
Keurig b30 turn on here motor, no water comes into cup!!!! help
It takes about 3 minutes to brew. You cannot use a clear coffee mug (scensors won't detect it)
You should be able to turn it on, Then place k-cup in holder, Then close lid and water reservoir lid will pop up and you add desired amount of water. Then push lid down, place mug under spout and the blue light will light up and you push taht. Within 3 minutes you should have some coffee
Apr 08, 2010 | Keurig B100 Coffee Maker
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
Cell Phones Logo
67 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
