Question about Dell V7 (U1868 ) ( u1868 ) Tape Drive
Hp sonic digital media plus no drive detected
I have burn cd / dv sonic but went i try no drive detected
dauphine
  • 207 Answers
SOURCE: blank dvd media is not reconized
You have to pre-select type of media in your burning program (CD or DVD) before adding files and commencing burning procedure.
Posted on Apr 10, 2008
SOURCE: DVD drive
You need to by a disk for cleaning your CD-ROM. The laser has more than likely gotten dirty. Someone has put a dirty CD into that drive. It only takes a spec of dust to do this. Always wipe your CD'S with a cleaning cloth from the inside edge outward before you ever put them into your CD-Rom. Never clean in circles. You can buy a kit for this at Walmart or a Computer store.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future
Posted on Jun 04, 2008
techniwiz
  • 275 Answers
SOURCE: can't burn an audio cd on my dell inspiron 1525
do one thing
go to the my computer > right click on the burner drive > properties > recorder > and than chk if that the recording option is checked or not
if not check it
if it is alread there
right click on my computer > properties > hardware > device manager > click on cd /dvd drive and uninstall the options there
than click on the IDE / ATA
and uninstall the secondary chanel first
and uninstall the primary channel .... but be sure that you do this in the same sequence coz if u have a ATA hard drive thats normally connected to the primary channel and if u uninstall that first it will freeze the system... after that is done restart the system and issue resolved
Posted on Dec 06, 2008
siawolf
  • 749 Answers
SOURCE: Sonic record now program will not find cd drive
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. Your media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. Lower the write speed of your burner.
  5. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  6. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  7. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Posted on Mar 24, 2009
daniel_2489
  • 63 Answers
SOURCE: removed sonic record and now can not burn cd or
have you tried writing the files just by dragging the files onto the cd or dvd and then clicking write files to disk
or you could try and download a free burning software
e.x. http://www.nch.com.au/burn/
Posted on Aug 03, 2009
The liteon dvdrw will not burn a DVD
Perhaps you should reinstall the Sonic stuff, in case it was affected since the virus cleanup.  If the OS had some of its components quarantined from virus contamination, you are probably stuck reinstalling the OS...though of course you can search the web (and not least Microsoft.com if that's the sort of OS you use) for healing 'media detection' issues (w.r.t. your particular OS.)
Mar 18, 2010 | HP Pavilion a1610n PC Desktop
Sonic Digita Mdeia Plus V7 not recognizing disc drive
You could try another program to burn discs, try ImgBurn from http://www.imgburn.com/
Sep 18, 2009 | HP dc7600 Convertible Minitower PC Desktop
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
Hp compac dc51oo small form factor pc cant/wont burn cd's from media play nevo others programs help
Have you try sonic? That come with the Hp Compac pc softwares. Find the original two cd that comes with the pc, and look for the restore and drivers cd. or try to system restore the pc where you think the last time you burn cd on you pc.
Jul 07, 2009 | HP Compaq dc5100 Small Form Factor PC...
HP Digital Media Archive Pop UP
Reinstall Sonic MyDVD from the Application Recovery. A lot of HP computers have done this or produced that constant pop up.
If that doesn't work, go to:
Start > Run and type in msconfig in the box.
Then click the Startup tab and uncheck the box beside DMA (digital media archive)
Click Apply then Close. Reboot when prompted and you shouldn't get that annoying pop up any longer.
If you don't even use the Sonic MyDvD program on the computer, just uninstall Sonic completely from Add/Remove.
Mar 09, 2009 | HP Pavilion Media Center TV m7680n PC PC...
I have an internal HP DVD Writer 740b that writes on CD but not on DVD. I tried Sony DVD RW and Memorex DVD-RW to copy files on but I failed. I use Nero Essentials to burn. The dialogue box keeps saying no...
DVD-RW drives have 2 different designs, 1 used dual optics, 1 for CD one for DVD, the other uses optics that can refocus between the media types.
If you haven't done so already, flash the firmware of the drive to the latest available from HP.
Assuming that the drive worked with NERO previously, If that doesn't resolve, you will likely need to replace the drive.
If you have not used Nero with that drive for DVD media, you might try a different SW and see if Roxio/Sonic will see DVD media in the drive.
Aug 13, 2008 | HP Computers & Internet
Sonic Media Player destination drive is unavailavle for burning CD's, etc
Most problems are related to OS. When asking for assist, tell OS and was it reunning before on same system?
Feb 14, 2008 | HP Pavillion a818n Desktop PC (Refurb)...
HP DVD/CD Burner 300n
Ok try this DO NOT insert the media until you have completed ya assembly... then tell it to "Burn" it will then ask for the media.. at this point insert ya CD... it should be "Detected" and ya Burn should proceed.I have had this work for me before. Also try Alcohol 120% thats a great Burner. As well as CopytoDVD...
Sep 04, 2007 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
DVD-RW drive not detected in my laptop by SOME software
I am asuming your using XP, this happened to me a few years ago, i searched google and found a forum that had instructions on editing a registry key to fix the problem but i wasn't able to see the drives in the device manager at all, so check that first and make sure they are there and try reinstalling the device drivers,using windows update or manually search for newest version of the drivers, if all that fails try reinstalling the applications your having issues with, if that fails you can try getting another application to replace the ones that aren't working, try alcohol 120% or Nero, those are about the best out especially a120 however it would require a purchase.
Apr 12, 2007 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Computers & Internet Logo
963 people viewed this question
Alun Cox
