Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter Thermostat fan won't turn off
I have a Hunter Thermostat model 44260. When heat turns off, fan keeps on running. I have flipped the HG-HE switch on the back and that temporarily works. However, once the heat kicks back on again and then off the fan fails to stop. How do I fix this problem? Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
My Janittol HPT 18-60 has posts marked Y, G, R, O, W2, E and C. The Hunter thermostat 44260 has fewer post connections G, RC-RH (with Jumper), Y/O, W/B, and Y1. What is the conversion and which wires are...
If your current thermostat is using all of the posts, you most likely have a dual stage heat pump system. A dual-stage heat pump system utilizes electric strip heat as backup heat for use during defrost cycles and to supplement the heat during outdoor temperatures below 30 degrees.
Here is an excerpt from the installation guide of the Hunter 44260 t-stat as well as a link to the guide itself.
"This thermostat is not designed for multi-stage heat
pump systems"
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42711.pdf?n=6278
Feb 25, 2010 | Heating & Cooling
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
I am trying to hook up a Hunter 44260 t-stat. The old one(not sure of model) has the following hookup. White-O Terminal Green-G Terminal Red-RC Terminal Yellow-Y Terminal then jumped to W Terminal...
Here is some basic info to help you. On the thermostat the letters mean... G is for your blower fan, and is usually green, Rc and Rh are power for the heating and cooling circuit (24v) and are usually red; Y (or in this case Y/O) is power to the cooling contactor (outside the house) and is usually yellow, and W (or in this case W/B) is the common wire, and is usually white. It kind of sounds like the people who installed the old thermostat followed these guidelines, so your best chance is to go to the heating unit and seeing where the wires connect to. Hope this helps
Jun 16, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
898 people viewed this question
Top Hunter Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
Paul Bade
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
