Question about Acer TravelMate C301XCi Tablet PC
Acer Travelmate C301XMi
I have this 5 in 1 card reader on my Tablet and it used to work pretty fine. But now, when I insert the card reader in nothing seems to happen... No extra drive appears on My Computer window as it used to come previously. But when you open the safely remove hardware icon (from where the clock is) it does show the Card reader as active on there. Please let me know how to fix this problem.. Thanks.
    New Friend:
  • 83 Answers
Re-install the driver for it,,, if you go to the manufacturers site you can re-download the drivers and this should fix your problem
Posted on May 08, 2007
How do I use an SD card reader on a Lenovo tablet?
Sometimes when you insert sd card into a card reader, the card reader will not always work, I have had problems like this, so either try another USB port on the computer, or clean the contacts on both sd card & card reader.
Feb 23, 2015 | Lenovo Tablets & eReaders
Why will my battery not charge?
I will assume you are finding the procedure to remove battery for the ACER travelmate C300 tablet PC. Best way would be to go to page 50 in the service manual available at this site.
http://tim.id.au/laptops/acer/travelmate%20c300.pdf
The battery not charging could simply be the battery is old and dead or the charging circuit is faulty. Start with the adapter in that case as it is cheapest to replace.
If you are removing parts to diagnose further then I would strongly suggest you video what you are doing in order to get back to where you started.
Sep 26, 2014 | Acer TravelMate C300 14.1 XGA LCD Display...
Where is internet switch on a acer travelmate c110 tablet pc
On the acer travel mate only some models came with wireless and others did not. If yours has wireless the switch should be located right on the front of the computer. I hope this helps
Jun 23, 2010 | Acer TravelMate C110 Tablet PC
Where is bios in a acer travelmate c110 tablet pc
To access the BIOS Utility, press F2 during the POST (power-on self-test) while the TravelMate logo is being displayed.
Can't get the wireless button to work CT110 Acer TravelMate
Sometimes the program "Acer ePM" (Power Management) takes priority. Check it at "Start" "All Programs"
Dec 29, 2009 | Acer TravelMate C110Tci Tablet PC
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Recovery Problems
The Tablets can be quite difficult to perform a reimage or recovery on as most bios versions on them do not recognise a USB device as bootable.
My recommendation would be to obtain a Bootable Floppy disk that contains an imaging program. (GHOST. Powerquest etc).
From here you may have 2 options available to you.
1. Attempt to recover using the hidden partition on your hard drive.
2. Recover from an image located via the network. You will need to ensure that a driver for your network card is also bundled into this install. Once this boothdisk has been created you will need to create a "shared folder" on another PC which contains the image you require. Once the bootdisk has loaded point yourself to the shared folder.
Lastly - You may be able to find an updated bios version that allows boot from USB device.
Apr 23, 2008 | Acer TravelMate C110 Tablet PC
Some keys of Acer Travelmate C 310 is not working
Replace the keyboard easily available for cheap. Get full manual at Acer website but replacement is easy, be careful of the clips holding the connection to the motherboard, don't remove just slide upward to release..
Sep 16, 2007 | Acer TravelMate C312XCi Tablet PC
Pen problem: need to push extremely hard
You should buy a new tablet pen from acer's website and see if that works that is the cheap fix if it works
May 29, 2007 | Acer TravelMate C302XMi Tablet PC
Acer TravelMate C301XCi Tablet PC Logo
112 people viewed this question
Top Acer Tablets & eReaders Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
