Question about Lexmark E238 Laser Printer
I have just bought a new photoconducter unit and put it in the printer. Instructions talk about select, return buttons, menu buttons and exit buttons. My printer does not seem to have this. It only has the on/off button and the cancel button. Can you help?
    Problem Solver:
  • 13 Answers
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover, as shown below.
    I have just bought a - pattlnk_1122005_2111-enus20330_openfrontcover_e230_en_us.gif
  4. Press and hold the Continue () button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue () button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button (pattlnk_1122005_1917-enus20682_cancelbuttonicon_e230_en_us.gif) to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low (pattlnk_1122005_215-enus20682_tonerlowbuttonicon_e230_en_us.gif) light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready I have just bought a - pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif22005_218-enus20682_readylighticon_e230_en_us.gif" alt="pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif" class="h_mi" />) light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
Posted on Jan 11, 2009
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
MFC9420CN brother printer says Check tray #1 Reinstall tray
I had this same problem. The solution was resetting it, and the instructions below worked for me:
2.3 Parts Life Reset Function
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
status.
(2) The "Reset Menu" will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the "1. Reset 2. Exit"
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Mar 03, 2011 | Brother MFC-9420CN All-In-One Laser...
I just installed a new photoconductor into my IBM InfoPrint 1622 and I need to reset the page counter and the instructions have been lost. I need instructions on how to reset the counter.
IBM infoprint 1622 - Photoconductor
When replacing a photoconductor on an IBM infoprint 1622 you must follow these following steps to reset the counter.
1. Open up the printer front cover and Install the photoconductor. 2. Close the cover. 3. Turn the printer off. Press and hold the 'Select' and 'Return' buttons, then turn on the printer. 'Config Menu' should appear on the display. 4. Press 'Menu' until 'Reset PC Cnt' appears. Press 'Select'. 5. Press 'Menu' until 'Exit Config Menu' appears. Press 'Select'. 6. Open the front cover. 7. Press and hold the red 'Cancel' button with the triangle on it for 3 seconds. All the lights should then cycle. 8. Close the front cover. The Photoconductor Maintenance counter is now reset.
Feb 21, 2011 | IBM Infoprint 1622 Laser Printer
How do you reset image unit counter on Xerox Phaser 6110MFP
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to desired counter and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
Feb 01, 2011 | Office Equipment & Supplies
I have chnaged the photoconducter but still comes up with error message, how do i clear this?
Hello, follow this steps:
1. Turn the printer off
2. Whilestill off, press and hold SELECT and RETURN buttons
3. Keep both buttons pressed and turn the printer on
4. Continue to hold both until either PERFORMING SELFTEST or CONFIG MENU appears on the display
5. Release buttons
6. RESET PC CNT should now show o the display. If it does not, press left or right menu buttons until it does.
7. Press select buton once. RESETING PC CNT VALUE should show on the display.
8. When the display shows CONFIG MENU again, turn the printer off.
9. Turn the printer on (do not hold any buttons down thi time). Printer is reseted.
I hope this simple steps will be helpfull for you. Good luck!!!
Mar 30, 2010 | Lexmark E342n Laser Printer
Light 1 and 4 continue to blink after photoconducter and toner changed
You need to reset the printer because it is not recognising the new conductor and cartridge. Turn off the printer
Hold the button (return) and power on
release the button when "Performing self test" is displayed
Select "Reset PC count" and press Select, the counter will Zero.
Hope it works!!! Shinal(FJ)
Mar 04, 2010 | Lexmark E250d Laser Printer
How to reset maintenance counter on a Dell 5310
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
Jul 21, 2009 | Dell 5110cn Laser Printer
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Aug 21, 2008 | Lexmark T644dtn Printer
Restarting all data on printer
Here is how you reste the printer fo default settings.
The Clear System Data Memory option restores all the user-selectable options to the factory defaults.
  1. Press the [Menu / Exit] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button repeatedly to select [Memory Clear].
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select [Machine Setup].
  5. Press the [Enter] button.
  6. Press the [Left] or [Right] arrow button to select the required option: [Yes] or [No].
  7. Press the [Enter] button.
  8. Press the [Menu / Exit] button to return to the previous menu.
  9. Press the [Stop / Clear] button to return to the Standby mode
Nov 19, 2007 | Xerox FaxCentre F12 Laser Printer
Lexmark E238 Laser Printer Logo
810 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
