Question about HP Photosmart M407 Digital Camera
HP Photosmart M407
You said that you had replaced a flash board in this camera to fix a flash not working and batterires not charging. I have those problems and have a docking cradle for recharge that the camera is in all the time it is not being used. I have replaced this camera but would be interested in fixing it rather than just throwing it away. Can you let me know where I can get the flash board and how you went about it. I read your reply to someone else that you could give them instruction if they wanted. Thank you for your help.
  • jontammy Jan 17, 2009
    All I can find is a used flash board and I do not feel confident enough about buying a used part that might also be bad or go bad in a short time. I guess I will just toss the camera and buy a brand I feel I can trust. Canon/Nikon
    Scholar:
  • 54 Answers
Go search for this ebay item 350138808473 and purchase the flash assembly for the m407. Other options is to search broken m305, m307, or m407 cameras (the components are interchangeable) that have working flashes. The batteries I suggest purchasing new rechargeables batteries and try a fresh charged pack. It may not be a bad idea to also purchase a AA battery recharger. You will need precision screw-driver set and electrical tape.
There are six screws on the outside of the case. Remove the six screws and gently pry the case open and remove the camera from the case. I found that placing my thumbs around the Tripod stand and opening as if it were a **** works.
The next step is to remove the LCD and the button board. What holds them in place are two small screws next to the bottom of the LCD. Remove the screws and small aluminum frame around the LCD. Using a small flat-head precision screw driver, gently pry the LCD loose from the base that is soldered to camera main circuit board. The LCD should be hanging by the ribbon cable. Using the precision screw driver, gently loosen the prongs that hold the LCD in place. After the LCD has been remove, remove the button board, which should be loose (it snaps into the main circuit board and it is taped to the flash assembly. Try to have as much of the tape on the button board after removal. You can use packaging tape to replace the tape.
WARNING: The flash assembly contains a 330 V capacitor. The flash assembly is covered with black electrical tape to prevent accidental contact to any expose metal. Contacting the metal will give you a good size shock.
The next step is to loosen the flash assembly from the camera. In the back of the camera, underneath the LCD and button board, there are three black screws that holds the battery chamber in place. Remove these screws, but the chamber is also screwed the flash assembly. Turn the camera around. You will see that there are three items attached to wires that you will have to either pry or snap off. The first is the switch by the battery door. The next is the speaker that is snapped into the assembly. The last is a disk that is sticked to the batter chamber (via an adhesive) Gently pry each of these loose (using a small flat-head precision screw-driver) and leave each component hanging from the wires.
There are two screws that attach the battery chamber to the flash assembly. You will need to look for theses screws underneath the black tape. The first one is easy because it the edge of the assembly. The second one is located in the middle of assembly and you will have to lift the tape to expose the screw. There is a third screw that holds the small valance of the flash bulb. This can stay on. Once the screws have been removed, the battery chamber should dangle out. (PS. This exposes the SD card slot if you need to straighten out bent copper prongs that prevents your card from being read.)
The assembly is plugged in to the main circuit board. This is located behind the capacitor (which looks like a battery.) Special care is require to wiggle or pry the open the plug to avoid damaging the plug from the flash assembly or from the main circuit board. I usually sit the camera on the table and stick the precision screw-driver in that area behind the capacitor and carefully pull the screw driver up. Once the flash assembly is loose, it should plob over to the overside, being held together by a copper foil that has been soldered to both the flash assembly and main circuit board. Try to leave as much of the copper foil behind with main circuit board as you tear the foil to fully remove the flash assembly.
Plug the good flash assembly into the slot on the main circuit board. Tuck the copper foil back underneath the tape. Screw the battery chamber back into place. Tuck back the battery door switch, speaker and disk back into proper location. Replace any black tape with electrical tape. Assemble the button board and LCD back into the main circuit board. Screw back in the alumnimum frame. Put the main camera inside the back half of the camera plastic case. Put the battery door in place (this may fallen off when removing the case. Snap in the front case and screw the case shut. Test the camera for functionality.
Posted on Jan 05, 2009
  • Amandio Rua Jan 17, 2009
    I gave you that auction because it sell the part that you need.. If you are not comfortable from buying the used part, then you will not be fixing the camera. All the parts that you need came from used cameras; therefore, there are used parts because HP no longer this or any other digital camera. If you wish, instead of throwing away the camera, send me the broken the camera so that I can fix it.
How do I fix my M407 Live view
I did answer this one. I.m sure. Your other confirms what I thought. Your sensor can't deliver pictures to the main board.
Jul 17, 2014 | HP Photosmart M407 Digital Camera
Battery won't charge on my HP photosmart M407. Batteries are new. What else might be wrong?
It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
May 19, 2010 | HP Photosmart M407 Digital Camera
Were can i get manual for m407 photosmart camera ,hp regulatory model fclsd-0411
Everything is under Hp website. i did download all my stuff including firmware etc from hp.
Mar 23, 2010 | HP Photosmart M407 Digital Camera
How much will it cost me for a replacement screen?
Comes around $25 at a service center. Suggest you buy a broken M407 with a good screen from ebay (or etc) and try fixing it yourself. Even I had experienced the same ended in paying lot of money. This camera does not worth spending so much. Or suggest invest in a new DC. Jimmy, Bangalore
Jan 01, 2009 | HP Photosmart 435 Digital Camera
Flash
Flash board is located on the top of the camera and it contains your shutter and video buttons. It also contains a 330 V capacitor that stays charged. If there is no charge, then the camera will say flash charging. If the camera persistently says flash charging, then the flash on your camera stopped working.
I found a flash board on ebay for 10 bucks plus shipping. To repair the flash involves in taking the camera apart. It is can be tedious but it is rather easy to do. If you are interested, I send you detail instructions.
May 09, 2008 | HP Photosmart M407 Digital Camera
HP Photosmart M407 Digicam
The issue is probably the button board on the camera. To open the camera, remove the six screws and pry open the camera from the bottom of the camera to remove the outer casing. Turn the camera so that the LCD is facing. Remove the aluminum frame around the LCD that holds the button board in place. Check the button board for mis-aligned or damaged discs (ie playback or view buttons) The discs are taped and may creep out of position. If they are out of position, push them back with the blunt edge of a screw-driver. If it looks fine, reassemble the camera.
May 01, 2008 | HP Photosmart M407 Digital Camera
Hi, can you help me with this?
is it a brand new camera? how long have you had the camera? are u puttin the batteries in the correct way? maybe u can try different batteries for now see wat happens if not write me back.
Hope this helps!!!
Apr 19, 2008 | HP Photosmart M407 Digital Camera
On off button
are the batteries fully charged?
Jan 12, 2008 | HP Photosmart M407 Digital Camera
CAMERA IS NOT FLASHING
The camera is recharging the flash. (possible cause)
Solution: It takes longer to charge the flash when the battery is low. If you see this message alot, you may need to replace or recharge the battery. Hope this helps!
Nov 27, 2007 | HP Photosmart M407 Digital Camera
HP Photosmart M407 Digital Camera Logo
233 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
