Question about Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Trying 2 reg Nuvi 200 and down load usb drivers and lost all maps. Display reads "NO detailed maps found that support routing. The Nuvi Cannot be used without them." Can U Help
  • 1 more comment
  • Anonymous Jan 01, 2009
    lost maps
  • Anonymous Jan 03, 2009
    After a normal use I turned off garmin and when I turned ti on it says the error message
  • Anonymous May 23, 2009
    turned on as normal and it had me press dots to calibrate and then all maps and settings were erased.
  • 21 Answers
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Posted on May 27, 2009
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
MY GARMIN NUVI 200W NOT WRONG AND SAY NODETAILED MAPS FOUND THAT SUPPORT ROUTING. THE NUVI CANNT BE USED WITHOUT THEM
Posted on Sep 22, 2008
  • 48 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
Posted on Jun 02, 2009
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Posted on Jun 20, 2009
sharcnet
  • 2130 Answers
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Posted on Jul 17, 2009
SOURCE: my garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
Posted on May 23, 2010
My gaRMIN NUVI 200 lost it's maps information. How do I recover the information. thanks
You can try contacting Garmin and seeing if they will allow you to download the map again. The file that you are looking for on the Nuvi's flash drive is "gmapprom.img". It should be within the Garmin directory on your Nuvi (using PC to Nuvi USB cable). The file will be very large, around 1GB. More information on missing maps can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Apr 19, 2014 | Garmin nuvi® 200 Car GPS Receiver
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
My garmin nuvi 200 it say no detailed maps
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
Hope this helps!
19. Close the file.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuvi® 200 Car GPS Receiver
- Jim
SHARCNET-USA
Jan 11, 2009 | Garmin nuvi 200 Car GPS Receiver
Lost maps in garmin nuvi 200
Form Message You need to have Garmin Tech support send you this attachment; "gmapprom.unl" Then follow the instructions below.
1.) Save the attachment from our message to the desktop
2.) Right-click the file gmapprom.unl, and click copy
3.) Click on My computer
4.) Click on the Garmin Nuvi drive
5.) Click on the Garmin Folder
6.) Rightclick a blank white space in this Garmin folder
7.) Click Paste, and note gmapprom.unl file is listed, please also delete gmapsupp.img if present
8.) Unplug the device, and allow to start up
Nov 04, 2008 | Garmin Nuvi 350 Car GPS Receiver
Oct 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
931 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
