MY DELL COMPUTER DOES NOT RECOGNIZE MY MOUSE OR KEYPAD WHEN I BOOT UP IT SAYS KEYBOARD FAILURE I KNOW BOTH WORK BECAUSE I CONNECTED THEM TO ANOTHER COMPUTER PLEASE HELP
  • 1 more comment
  • wodi1115 Jan 23, 2009
    i have the same problem and my keyboard and mouse both work on a nother computer
  • nyxt00 May 11, 2010
    Are you using a PS2 (small round) keyboard or the USB keyboard which is what most people are getting now? And what operating system are you using.
  • Dutyacx May 11, 2010
    have you tried another keyboard ?
    If the mouse has problems, you will not receive a message, but it simply won't work.
    If possible, can you please use another keyboard with another connector type (PS2 or Mini DIN/USB) ???
    Problem Solver:
  • 6 Answers
Under BIOS settings, check that the Mouse and Keyboard [may be worded differently] are enabled, and not disabled. Also, if your using Windows then check that the devices drivers under device manager, under system. Update them. If still not working, boot up in safe mode and see if they work in that mode. If they do, then your OS files are corrupt, if not, buy a new keyboard and mouse.
Posted on Jan 01, 2009
Keyboard failure
This may be an issue with your usb drivers. Update those first, then if that fails, I would try one of those adapters that goes from USB to the old school mouse and keyboard connections and plug that in to see if it works.
Sep 24, 2012 | Dell Inspiron 640m Notebook
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
I have a dell wireless mouse and it used to connect with my computer and work fine. I've had it almost a year but now it will not connect to my dell laptop. The light on my laptop and on the mouse will...
Most wireless keyboards and mice have their own wireless receivers (one that should be connected to the computer). The wireless receiver usually has a connect button that you need to press in order for you to connect the keyboard or the mouse. Try holding down the connect button on the receiver and on the keyboard at the same time for five seconds and release them both after five minutes.
If that work, do the same for the mouse.
Hope this helps and have a great day!
Jul 06, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Computer doesn't recognize keyboard
This is sort of general but it just may help.
Make sure your batteries are in correctly.
Make sure the transmitter dongle is in the USB.
Look on the transmitter and the mouse and keyboard
itself (bottom) for a little tiny button that says connect
or reconnect. Move the mouse about six inches away from
the transmitter and press both the transmitter and the mouse.
That should reestablish the signal twixt the two.(or three KB)
May 14, 2009 | Dell Bluetooth Wireless Keyboard/Mouse for...
Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Apr 12, 2009 | Dell PowerEdge 1600SC Server
Wireless Mouse Just Stopped Working
Press the connect button on the reciever and then the connect button under the mouse for the computer to recognise it again.
Hope this helps
Nov 01, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Mouse and Keyboard not recognized
i think ur computer hangup after booting
there may be some problum in ur op system . it hase virous.
2nd u test ur mouse and keyboard to another computer if they work correctly u have to reinstall ur op sys
u can call me 91-9329204658 india
Jun 01, 2008 | E-Machines eMachines Desktop PC
Wireless keyboard doesnt work with switch
once you have switched pc you will need to re-sync the wireless keyboard and mouse with the new pc, because although you have switched pc the keyboard and mouse do not know this. there should be a reset/resync button on the bottom of both the keyboard and mouse
Jul 30, 2007 | D-Link DKVM-2K 2-port KVM Switch
Computers & Internet Logo
233 people viewed this question
David Payne
David Payne
