Question about Epson Stylus Photo 1290 InkJet Printer
Printing problems I am getting blue lines across anything I try to print. It looks like the cartidge is bleeding ink at intervals. Does anyone have a solution for this problem. If so could you please let me know as I am completely out of solutions. Tried cleaning the heads and aligning but this doesn't solve the problem. Totblot
  • Epson Master
  • 705 Answers
It could be that the underside of your head has a clump of ink on it and this is dragging across the paper. Contact http://www.TheServiceManualShop.com for there document about head cleaning - the document is not listed on the site but they can email it you. If this is not the issue then it could be that a cart has leaked into the cart carriage and is colouring one of the other inks. This is not that likely however as blue is a primary colour and can't be made by mixing inks. If it was for instance green bands that it would be plausible that blue ink was leaking into the yellow or vice versa. Another option is that the piezo thing that actuates the ink being fired is capput and allowing blue to leak through to the nozzles all the time. Or that the print head or main board is faulty. I'd try the cleaning first - it's the easiest option.
Posted on May 07, 2007
Why blue lines when document printing?
You need to do a head clean you should be able to find this in maintenance section of the printer program.
They get a little dry spots or dirt on the cartridge.
This is a ink eater so uses a heap of ink could take 2-3 head cleans to clean it.
Regards Craig
Feb 11, 2018 | Office Equipment & Supplies
My Epson R320 prints blue lines across and over all my printing including DVD printing is the anyone out there that can help it loohs just like a writing pad that contains lines peter
Epson told me it needed to be serviced but I did not accept that. It was hardly used. But everything I tried failed at first. Cleaning the print head barely showed any inprovement. Finally I just removed all the ink cartridges, then just put them back in. Something reset is my guess. Cleaned again and now it is printing without any lines. As good as new so far...
Nov 17, 2010 | Epson Stylus Photo R320 InkJet Printer
When printing photo's on my Cannon Pixma MP 500 there are lines horizontally across the photo at 4mm intervals. I have tried head cleaning and alignment to no avail. I have tried both Cannon original ink...
It's probably a blocked jet in the print head but could also be a page registration issue. Try gently wiping the print head with a cotton bud dipped in an alcohol based cleaner
Nov 28, 2009 | Canon Office Equipment & Supplies
Light blue lines keep printing behind my black printing areas on word documents
this means the black ink is running low and the printer is tryin to resolve this issue with bringing colour to take half of the black ink cartidges process, this just saves on ink, its usually called ecconomical mode, you can turn off this feature. or alternatively this may be cause by low ink in general, try replacing the ink cartridge.
hope this helps.
kev
Dec 01, 2008 | Office Equipment & Supplies
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
cheers
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
