1) Unplug from power
2) FOLLOW Anti-Static Precautions
[Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return ]
Gateway Support > Gateway GT4010 Desktop PC > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2809Click on the Support Documents tab.
(Driver / BIOS / Applications / Patches / Support Documents / etc)
Click on the blue -> 5891 - Support Documents subheading
Click on Product Views.
Click on Rear View
Viewing the Front of your computer the Right Side Panel removes.
There are two Thumbscrews to loosen, shown by the letter C.
(They are supposed to remove all the way. If they do it's OK)
There is a finger-pull formed out of the back of the left Side Panel.
Pull towards the back of the computer. It should then swing out at the top, and can now be removed.
Go back one page, and this time click on - User Guides
Click on -
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
Took 10 seconds just now using a medium speed DSL connection)
Go to Page 51.
Now I would like you to go to Page 52 - Removing the front bezel
The Front Bezel is the Front Panel, of your computer.
It has 6 tabs that lock it on the metal frame of the computer case.
There are 3 of these tabs that you access, from the Side Panel opening.
It is only these 3 that need to be accessed, in order to remove the Front Bezel.
Looking at the inside, of the Front Panel, and the edge that meets the metal framework of the computer case;
One tab near the Top.
One tab in the Middle.
One tab towards the Bottom.
These tabs are plastic, and are formed out of the plastic Front Bezel.
Press the Top tab IN. (Not too hard or it may break)
Gently pull the Front Bezel towards the front of the computer, JUST A LITTLE.
Now press in on the Middle tab.
Finally press the Bottom tab in.
(Each tab has a flat hooked end. The tab itself goes through a slot, in the metal framework of the computer case. The tab must be pressed in far enough, so the flat hooked end will clear the slot, and allow the tab to slide through the slot; when the Front Bezel is pulled forward)
Tabs clear of the metal framework of the computer case; right side of Front Bezel swings out a little. (Viewed from the Front; Right side)
This will allow the tabs on the other side to release from the metal framework of the computer case.
NOTE*
It looks as through the Power On switch is attached to the Front Bezel.
This means use CARE, and ease the Front Bezel forward a little, away from the computer case.
Wires are still attached.
IF, you pull on the Front Bezel too hard, or too far; the wires may become unplugged from the motherboard.
IF, this happens, do not worry.
Here is the pinout information for all of those wires,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtmlClick on Product Views.
For example; The Power On switch connects to the Front Panel header, on the motherboard. For this pinout click on -
W - Front Panel connector
9-pin header.
4 pins across the Top row.
5 pins across the Bottom row.
Starting on the Left side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side, going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
(Light. It's a Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt check point reserved for the factory.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
IF the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
There is nothing(?) like removing a Front Panel (Front Bezel), and finding out you accidentally unplugged wires from the motherboard; and there is no pinout to connect them back.
Just makes you so HAPPY
!O_O!
Power On switch replacement:
The Power On Button is an assembly. Every pre-built computer manufacturer has their own design, and it can vary from MODEL to MODEL.
The main thing here is, the Power On switch usually doesn't.
This ATX power on switch is used in MANY models of Desktop PC's,
http://www.directron.com/atxswitch.htmlI know it's hard to see here, and I apologize for that. Best example I have found.
View what looks to be a metal square cap in the front of the view.
There is a small post that sticks out.
This post is what the plastic part of the Power On Button assembly, presses against.
Power On Button assembly may have a plastic post itself, which is returned with a coiled spring, once the Power On Button is pressed.
Or the plastic button itself, presses against that Power On switch post.
You need to soften the plastic of the Power On Button assembly, in order to remove the Power On switch.
The plastic tabs of the Power On Button assembly may break, if this is not observed. Also compounded by the fact, that the plastic of the Power On Button assembly, has been heated several times, and is now brittle. (Plus age)
I use a hair dryer set on low, (Thanks honey. I'll be right back with it, lol!), and slowly wave the nozzle of the hair dryer, back and forth across the Power On Button assembly.
Once the plastic has softened some, ease whatever tabs you need to gently move aside a little, to ease the Power On switch out.
Be aware that the plastic will cool almost instantly, and need to be softened again, before attempting to replace the Power On switch.
Or perhaps june_sells20 this is the best way to go,
http://www.ebay.com/itm/Gateway-Brushed-Aluminum-GT-Series-5-Bay-uATX-Front-Bezel-8016758R-6378-/271069731471?pt=US_Computer_Case_Accessories_Tool_Kits&hash=item3f1d03da8fNot advertising for seller, nor website. Just reference.
For additional questions please post in a Comment.
Regards,
joecoolvette
