Cars & Trucks Logo
Anonymous Posted on Jan 01, 2009
Replacing a 4L60E with a 700R4?
I have a 94 Chevrolet 1500 (4X4 with a 5.7 liter) pickup with the 4L60E tranny. Can I remove the 4L60E and replace it with a 700R4 (and obviously not utilize the computer). If so, will this ''mess'' with the ecm?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2239
Points
I have a 99 suburban and it is slipping trying to go into 3rd and won't maually shift into 1st and 2nd
  • mike 20074 Mar 17, 2015
    This will need a full rebuild
Anonymous
Level 2:
  • Expert 180 Answers
  • Posted on Jan 01, 2009
Anonymous
Expert
Level 2:
Answers
180
Questions
0
Helped
72560
Points
353
Not with good results, the 4L60E is run by your ecm, the 700R4 while looking close to the same does not relie on your ecm for commands,it relies on a cable to regulate your line pressure.
1helpful
Why won't it shift into 3rd or 4th?
It doesn't sound right, the majority of the Chevrolets from the smaller jimmy to the full size pickups had 4L60E transmissions in them. Reverse works fine as well? Could possibly be a shift solenoid.
Wiring 99 4l60e 4x4 tranny from suburban to 98 pickup problem
Hi Jesse, You need to get the correct management system and probably the wiring harness to go with it. It will also require someone conversant with electronics and who knows the circuit of the vehicles concerned. Regards John
Will 400 transmission fit my 1994 c1500 pickup with overdrive
no. in the late 80's chevy switched to a electronic automatic tranny called the 4L60E, that is the tranny you should be looking for. the only bad part, its more expensive.
4.3 liter, Rocker nuts back off at idle
I would try using some Loctite Threadlocker, they offer different strengths, removable and non-removable.
2helpful
93 chevy 4x4 with a 4l60e tranny. will a 98 tranny swap?
Nothing after 1995, because from 1996 on the transmissions are for OBD II. Your truck has OBD I.
Swapped tranny, just need help with matching up wiring
It won't work. The shifting of the 4L60E is done by the computer in the 93. You might check with Summit or Jegs, I think they make a system to make it work.
I just installed a used 4l60e in my '97 Tahoe. On test drive, it shifts from 1 to 2, then about 1/2 way to 3, it downshifts back to 1. Any ideas about the problem?
how many miles on the tranny your put in? those don't last any more then about 120-140. the sunshell breaks, you should replace it with "the beast"
all shifting is in the valve body, you don't need to remove the tranny again. If your going to open her up and start wrenching, get a video/book on the 4L60E, you will start with check electrical components
1helpful
4L60E slipping and not locking up
Very well could be taht the Computer is not recieving the Shift codes Correctly. Just for an Easy Solution, Remove the ECM Fuse from the Fuse panel for 2 or 3 Minutes to Reset the Computer and let me know what you get.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
