Question about Fisher and Paykel GWL11 Top Load Washer
Hot water doesn't work
The washer will fill on the cold water setting but not on the hot water setting.  Also, once the washer gets started it will stop after the filling cycle.  After powering the Machine off and back on it will resume where it left off and finish fine.
  • Anonymous Feb 15, 2009
    Only cold water works in the washer, there is hot water going to the adjacent bathroom, but only to the shower not the sink.The washer stops after the first cycle, and I have to reset it to rinse and spin out the soap. The washer is almost new and have no clue what it could be.
    Novelist:
  • 161 Answers
Disconnect the hot water hose from the washer, put the hose over in the washer and run some water to make sure you don't have a plumbing problem. Look inside the valve where the water connects to the washer, there should be a screen that may need cleaning.
If everything looks and works good to this point then you will need a meter to see if power is getting to the water valve and to check the hot water solenoid on the water valve. No power to the water valve, then replace the water select switch. Bad solenoid, then replace the water valve.
Posted on Jan 01, 2009
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont fill with water when switched on
Fillingwith water:
The waterfill valve - The water fill valve is a mechanical and electrical part,the coils on the valve need electricity to mechanically open the valve to allowthe water to flow into the washer....myth....the washer pumps water into itself...no, itdoes not. The fill valve opens and the house water pressure pushes the waterinto the washing machine.
No cold wateror no hot water - The fill valve has two coils, one for the hot water and onefor the cold water. It is possible that one of the coils can fail and you loosethat filling ability. If the cold water coil quits, the hot will still work andduring warm fill you will get hot water only and during a cold fill you willget no water at all. If the hot coils quits, you will still have cold waterfill, cold water only on a warm setting and no water on a hot fill setting. Youcan No cold water or no hot water- The fill valve has two coils, one for the hot water and one for the coldwater. It is possible that one of the coils can fail and you loose that fillingability. If the cold water coil quits, the hot will still work and during warmfill you will get hot water only and during a cold fill you will get no waterat all. If the hot coils quits, you will still have cold water fill, cold wateronly on a warm setting and no water on a hot fill setting. You can testa fill valve live for 120volts, power to a fill valve coil and no fill = a bad fill valve. You can also testthe coils for continuity, nocontinuity = a bad fill valve. Some Maytag washers have a fuse in the fillvalve circuit, if this fuse let go the washer will not fill. Fill valves canalso from time to time stick open and not stop filling. If you have to shut offthe fill valves to stop the water fromfilling in the washer, you have a bad fill valve and you will have to replaceit.
Water level controls - The water levelcontrol is also know as apressure switch, this is where you set the water level ( small - medium - large). The water level control is responsible to shut off the power to the fillvalve and direct that power to the timer so the washing machine can start up.The WLC has electrical contacts in it that sends power to the fill valve and whenthe WLC is satisfied the water level is correct the electrical contacts openpower to the fill valve and send the power to the timer and the washer starts.Picture of this here. How the water level control knows when it istime to shut the water off is, a air tight hose runs from the outer washer tank to the waterlevel control. As the water fills the outer tank air is pushed up the hose,depending on which setting you have made ( small- medium - large ) is takes acertain amount of this pressure to make the WLC cycle over and shut off the waterand send this power to the timer. If this hose develops a leak or a pin holethe washer can over fill as the WLC may not be able to shut the water off. Thewater level control can also break down and allow the washer to over fill aswell.
Testinga water level control or a fill valve can be done by using a Testing a water level control ora fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter. Testing a waterlevel control or a fill valve can be done by using a ohmmeter or a voltmeter.
You can get required parts from www.repairclinic.com
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Jan 16, 2010 | Zanussi FJS1225W Front Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Fisher and Paykel GWL11 Top Load Washer Logo
191 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
