Question about Sport & Outdoor - Others
My ski went side ways going down the trail any i dea what could be wrong with it
    Scholar:
  • 71 Answers
It was on the wrong boot. Just switch these and you will be fine.
Posted on Jan 01, 2009
I have a1998 skidoo 500 grandtouring handles horrible all over the trail. Darts all over. Ski adjustment? Suspension?
first check that your scags are good or new , now look at alinement of skis ,they should have a little toe in when looking from front of machine, if there strighr a head that will cause drifting left and right because skis get cought in ruts from other machines and causing pulling.
,also look for worn tie rod ends, or linkage from steering
.good luck hope you have fun out there .
Woody
Feb 15, 2015 | Cars & Trucks
How do I get rid of the trail card lock message that pops up on the screen when I turn my camera on ?
on the SD card on the left side of the card is a tiny switch,make sure it is pushed all the way up towards the contacts
Oct 27, 2014 | Moultrie Game Spy Mini M-80XD Infrared...
What now ?? my yamaha suv1200 Can the transmission be shot ?
there are no gears just a direct drive from the crank to a jet pump ! if theres no propultion of water it could be several things !
1. plastic bag etc in the intake to impellor pump assy !
2. impellor gap to housing too much ie worn impellor !
3. impellor not turning because splines on either the shaft or impellor worn !
4. drive coupler damaged and spinning on shaft !
Try running on a hose pipe and look at rear of engine ( remove plastic cover so you can see the 2part coupler and drive shaft ) .
Check the impellor assy !
Sep 08, 2014 | WSM 1999-2001 Yamaha Suv 1200 Cc Jet Ski...
What different types of cross-country skis are there?
there are two types
1. general touring skis -these are for track skiing. They are long, narrow, and light compared to metal-edge skis, making them more efficient and very fast. This makes them better to use for the groomed trails.
2. metal-edge skis -for skiing out-of-track or on steeper terrain. They are heavier than touring skis and have metal edges to grip the snow and ice. The edges also help with turning on steep slopes. They are meant for deep snow and icy terrain. They are wider in order to be more stable.
Feb 27, 2013 | Winter Sports
How many km of cross-country ski trails does the Dartmouth Cross Country Ski Center have?
the Dartmouth Cross Country Ski Center has over 25 kilometers of groomed cross country ski trails
Need a manual for vitamaster northern trails ski machine
If you're still in need of a manual for your Vitamaster Northern Trails Ski Machine, I have the manual and parts list.
http://reddeer.craigslist.ca/search/sss?query=vitamaster+manual
Sep 13, 2010 | Exercise & Fitness
There is a lot of play in the front skis on our 2005 arctic cat 600 M7. So when you are crusing on a trail, feels like you are out of control and throws you all over. Any suggestions? My husband has been...
Assuming all the steering linkages and bushings are in good order you need to adjust your toe in. If you have a camber adjustment check that first. If you remove the skis and run a metal rod through the ski on on side it should pass just under the the ski mount hole on the other side (about 5 degrees). The degree angle can vary from model to model. After you set the camber on one side then set the camber on the other side. Now adjust ski angle. The front of the skis should be toed out 1/8 to 1/4 of an inch.
Jan 17, 2010 | Interactive Toy Concepts Crossfire Arctic...
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
My ski went side ways when going down the trail
The ty rod is probably broke or disconnected from the steering colum inside the hood.
Dec 31, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
