Question about Kenmore Elite HE4 Electric Dryer
The front of my Kenmore gas dryer 110.94832201 drum is scrapping in the front on the blower below. What do i need to replace?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Sounds like the support rollers are failing. There are 4 of them. Here is a link to the roller kit.
Posted on Oct 16, 2012
  • app_3rp76689
    app_3rp76689 Oct 19, 2012
    Actually I tightened up all the screws on the machine after taking it apart first and now it is up off the blower house not scraping. But all of a sudden the heat is cycling on and off too much and clothes aren't getting dry. They were before I took it apart. Ideas?
  • Richard Roth
    Richard Roth Oct 19, 2012
    Check all the wiring connections in the area you were working. Also, check the thermostats for any lint that may have gotten on them.
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Kenmore 80 series dryer.
thanks for the question The noise might seem like its from the front but theres nothing at the front Now at the back you have 2 drum kollers By the motor you have aidler pully most times the idler is the problem you can buy a repair kit that comes with all the parts you need to fix noise belt , 2 drum rollers and idler pulley .replace them all . Thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: drum not rotating on kenmore 80 seires gas drier
Some repair pix with manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 09, 2009
Start switch buzzes and won't start the dryer
I had possibly a similar problem with a Kenmore 90 electric dryer. Sometimes pushing the start button would just make a buzzing sound, but the drum would not turn.
I ended up replacing the motor and so far it seems to start up smoother and quicker. In the process of taking it apart, there was a surprising amount of lint piled up in front of the blower intake. This is after the lint screen and not really possible to get to without taking off the lower front panel and then removing the duct to the blower. Perhaps it was dragging on the blower and causing the motor to overheat. Worth looking at first, perhaps.
Apr 01, 2014 | Kenmore 73952 Gas Dryer
Our 600 Kenmore Gas Dryer, makes a squeaking sound and the drum does not seem to turn freely!
Instructions Things You'll Need
  • Putty knife
  • Phillips head screwdriver
  • WD 40
tyn-hp.gifGet what you need for every
project at HomeDepot.com
    • 1 Disconnect the dryer from the wall outlet or the breaker/fuse box. Be sure that the dryer is disconnected before you continue.
    • 2 Raise the top of the dryer. You will do this by inserting a putty knife into the crack between the top and front panel. Push against the spring clips to release. There will be one clip on each side of the dryer. Once the top has been released you can disconnect the wires to the door switch located on the right side on the backside of the front panel.
    • 3 Using a Phillips head screwdriver remove screws holding the front panel to the side panels. Pull the front panel away and lift off the bottom clips to remove it completely.
    • 4 Remove the belt from the idler pulley. The idler is located behind the blower/motor unit. When the belt is free you can slide the belt to the back edge of the drum. Lift it straight up to disengage the rear bearing from cradle.
    • 5 Pull the drum out through the front of the cabinet. You will be able to see the drum support ball on the back of the drum and the cradle holding the ball.
    • 6 Apply a generous portion of supplied grease or spray WD 40 into the cradle. In almost all cases, this will resolve your squeak. Once you have greased the drum to your satisfaction, you can reassemble the dryer.
Read more: How to Fix a Drum Squeak on a Gas Dryer ' eHow.com http://www.ehow.com/how_4899504_fix-drum-squeak-gas-dryer.html#ixzz1PYDjwD8h
Lithium grease works best for this.
Jun 17, 2011 | Kenmore Dryers
I have a Kenmore 90 series gas dryer. When you push the "start" button, the dryer "hummms" for a few seconds and then it just becomes a click when you hit the start button. I have not...
Your dryer has a bad motor or something fell into blower wheel and not allowing motor to turn. The drum turns only one way because of locked motor. Will need to open top and then take front panel off to dismantle unit.
Jan 08, 2011 | Kenmore 75944 Gas Dryer
Kenmore Series 70 electric dryer 66702692 Dryer makes sluggish sound when hit start button./ Dryer heats up and does dry clothes for up to 5 minutes at best then shuts off. Typically shuts off...
Hello there:
please use this troubleshooting list i have pprovided below to help troubleshoot the problem and let me know how this is going ok
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 06, 2010 | Kenmore Dryers
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Dryer Drum Scrapping
You probably need to replace the slides:these wear down and cause the noise you are discribing.900bee5.jpg
Dec 22, 2008 | Maytag SDE2606 Electric Dryer
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
383 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
