Question about Jenn-Air JED8430 Electric Cooktop
Not working although power supply is on
We've had our cooktop for almost 2 years. today the power shut off and now the burners are not working although we've turned them on high and the fan still works. what could the problem be? and how do you think we could fix it?
  • 135 Answers
Very likely your power supply is faulty. With 220 volts both legs must have power for the burners, but the fan will run on only one leg. Hope this helps!
Posted on Jan 01, 2009
Kleenmaid CH600CE ceramic cooktop stopped working
U sure power is getting to cooktop ?- chances of all burners not working and/or going bad at same time is ridiculous.
Get out your VOM and start tracing the voltages back to point of inception.
Sep 17, 2016 | Cooktops
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    I have a Jenn Air gas cooktop, only about 2 years
    If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
    Jan 03, 2010 | Jenn-Air Cooktops
    We ordered a GE gas cooktop 2 burner module to replace the grill on the lefthand side of a cooktop we inherited (model JGP389WEVWW). The gas cooktop only had 2 burners with a grill, and since we want 4...
    THE BEST ADVICE I CAN GIVE YOU IS GO ON LINE TO
    REPAIRCLINIC.COM AND THEY WILL ANSWER ANY QUESTIONS YOU HAVE AND CAN GET YOU GOING IN THE RIGHT DIRECTION
    Sep 26, 2009 | GE Cooktops
    2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
    I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
    Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
    Only 1 of 5 burners is working on my Viking electric cooktop
    By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
    Dec 25, 2008 | Viking 31 in. DECU165 Electric Cooktop
    Hot burner indicator light won't shut off
    the switch for the bottom right burner is bad but doent not affect the cooking, just the light
    Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
    Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
    You have posted this to a public webpage that has 7 million visitors and is nothing to do with your electrician 'Eddie'. You have also posted your telephone number and email address to those 7 million viewers.
    Feb 27, 2017 | Jenn-Air 35 in. JEC9536 Electric Cooktop
    Inop burner on new jenn-air JEC9530 elec flat cooktop
    I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
    Sep 04, 2007 | Cooktops
    Cooktop's electronic igniter started clicking all by itself
    Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
    Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
    Jenn-Air JED8430 Electric Cooktop Logo
    66 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
