Question about Sony Xplod XM-1652Z Car Audio Amplifier
Wireing How do I hook up my amp if my factory stereo in my 2004 Ford truck dosen't have RCA jacks?
  • Scott Andrews Apr 17, 2008
    how do i connect the high level input to my factory speaker wires? Do you connect the front and rear left speakers to one pair of wires and the front and rear right speakers to the other?
  • retyred102 Jun 23, 2008
    I have xplod amp. my factory radio does not have rca plugs. How do I hook this radio to my amp?
I just dont no what wires go to what wires wen hooking it upp
Posted on Sep 18, 2008
I believe that this model Sony amp includes High Level inputs. Those allow you to connect the normal speaker wires coming out of the factory stereo to the amp. If for some reason it doesn't include the inputs you can buy a high level to low lever converter that will give you rca from the factory unit.
Posted on May 22, 2007
How do you hook up a subwoofer or a speaker box to factory stereo
Some radios on newer radios have RCA plugs tucked up in the wire harness to easily connect a sub amp. The sub amp you select will have the necessary instructions for hookup
Jan 22, 2017 | AMP Car Audio & Video
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How do you hook up a amp with a factory radio.. a 2002 impala
1- you need to provide a fused power wire from battery to amp
2- provide a ground wire from amp to car body or frame (be sure to clean off paint if connected to body)
3- connect your remote wire to your fuse box (16 to 22 gauge wire will be fine)
4- connect a line output converter which will allow you to use rca jacks (one side connects to the speaker wire in your car and the other to your rca jacks)
5- finish by connecting your speaker wires and rca jacks
if helpful please rate 4 thumbs up.
Jan 15, 2011 | 2002 Chevrolet Impala
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
Will a amp work with this deck
you can get a amp to work on any deck although u may have to rig it a little bit all u need is sound coming from the stereo and if u will take the rca one end and cut it and strip it u have a wire inside each one and then u have ground wires surrounding the inside wire twirl them up like 1 wire and then strip back the inside wire hook that one to front left pos wire and hook ground wire to front laft neg and do the other rca wire the same just hook it uo to front right or if it has rca jacks on the back of the stereo just hook ur rca wires into them and to the amp
Feb 24, 2010 | Pioneer DEH-1600 CD Player
What is needed to install rca jacks to amp on a factory radio for 97 ford escort
There is a spliter you can buy,but it seperates the wires in polarity to hook up to your factory.
Oct 27, 2009 | Boss Riot 1500D Car Audio Amplifier
How Do I Wire An Amp To A Factory Stereo Without Rca Jacks
Hello jon101478,
Purchase a line output converter (LOC) such as the PAC SNI-45T shown here. Tap the LOC inputs into your rear channel speakers and run RCA's from the LOC to your amp. The unit shown in the link also has a trigger wire that you connect to the remote terminal of your amp. You can get a cheaper LOC and just run a switched 12V source to the amp if you wish.
Hope this helps.
Jul 17, 2009 | Car Audio & Video
Speaker level converter
Is this meant for hooking up an amp and still using your factory stereo head unit? If so, you only need to use the four speaker wires. Go into the trunk and tap them into the rear speaker wiring per the labels on the converter's wires (right and left, plus and minus). Then plug your RCA cables into it and connect them to the amp.
Nov 23, 2008 | 2000 Ford Taurus
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
How would i add amp and sub to a factory stereo system
You can't hook it up like an aftermarket stereo, but there is a piece of equipment (cannot remember what it is called right now) in which you can hook regular speaker wire up to it and it converts it into an RCA jack connector.
May 23, 2008 | 2004 Dodge Neon
Sony Xplod XM-1652Z Car Audio Amplifier Logo
234 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
