Question about Car Audio & Video
I have a Goodmans 6 disc autochanger built in to my Range Rover Vogue which was installed at manufacture. It was working ok until the disc holder was taken out of the unit recently to play alternative cd's. Now for some reason, it will not acknowledge that there are any cd's loaded, hence it will not play at all. I have taken the holder back out to make sure that the discs are the correct way up, which they are and even inserted other discs but it still fails to operate. Any ideas?
  • brian_witts2 Jan 01, 2009
    I have a 6 disc Goodmans autochange built in to my Range Rover Vogue which was put in at manufacturer. It was working ok until we ejected the disc cartridge to change to other discs but now it will not acknowledge that there are any discs loaded, so hence it fails to play. I have checked the obvious things like making sure that the discs are up the correct way but still it does not work. I have had the vehicle for 12 months and it is 6 years old. Any ideas?
  • brian_witts2 Jan 02, 2009
    I will look at this but havn't as yet but thanks for the advise. much appreciated.
    Genius:
  • 1,199 Answers
It sounds like when it was taken out somthing got jarred and now your lens needs adjusted!
Posted on Jan 01, 2009
    Problem Solver:
  • 59 Answers
You could try to take it back to company they well fix it for free or a very low fee.
Rover workshop manual
You would be better off buying the Haynes manual that covers all aspects of the vehicle. If you can afford a Range Rover Vogue, you can afford the $30 odd for a manual
Jun 26, 2014 | 2005 Land Rover Range Rover
The battery of the range rover vogue 2004 is died and I can't unlock the door
It does have a key slot think its behind the right side of the door handle and you pull the plastic cover off
Apr 14, 2013 | 2006 Land Rover Range Rover Sport
Diagram for a drive belt for a 2004 range rover vogue
I need a diagram and instructions on how replace a new belt on a 2005 Range Rover V
Mar 15, 2012 | 2004 Land Rover Range Rover
After changing the battery of range rover 2000 radio asked for code, we entered the code many times but did not accepet although the code has 0 and no zero on buttens and now the screen displays WAIT.
Now since the wrong code was entered many times it can hang up. So disconnect power for a while and check again to see if the codes match.
Also if will be best to call and confirm with the database of your dealership - service support - for the correct code which will be recorded in your file.
Aug 24, 2011 | 2000 Land Rover Range Rover
My 2002 range rover 4.4 vogue central locking and front windscreen wipers have stopped working checked all fuses they are ok any ideas thanks
The Central locking might needs to be reprogrammed as it might be went into Transportation mode but the Ft. Wipers might be the column switch...these causes due to long time Vehicle being parked without usage
Apr 12, 2010 | 2003 Land Rover Range Rover
Hi, i have a bmw cd changer that keeps bringing a no disk error m
Remove changer, check fuse located on rear of changer +connections.Also check for water ingress.Common problem, good luck.
Sep 27, 2009 | 2003 Land Rover Range Rover
Range rover 2003 Vogue Gps system
i am interested to buy it as is . my contact i_buyl_aptops at , think the rest you will figure
Jun 27, 2009 | 2004 Land Rover Range Rover
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
