Question about Reebok RL1500 Elliptical
Reebok RL Space saver elliptical. put together. plug it in. Incline calibrates but then when try to use the machine the incline will not change when we hit the buttons. any ideas?
  • rnjen95 Jan 10, 2009
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    Myself and another put the machine together paying close
    attention to the directions. When we
    plugged the machines the display noted “calibrating incline.” However, the incline is not functioning. Attempts to reach customer service, during appropriate hours, has been unsuccessful.
Hey had the same prob. unplug and plug in again... worked for me
Posted on Jan 31, 2009
How do I find a user manual for a Reebok Space Saver RL Eliptical?
Call SportSmith and we will find it for you :) 888-713-2880 here is the link to your manual
http://www.manualslib.com/manual/508361/Reebok-Rl-725.html
If you find yourself needing any parts for your repair, if any. We would be happy to hear from you! We also do chat if you prefer, at www.sportsmith.net hope we helped out!
May 14, 2015 | Reebok RL 725 Elliptical Trainer
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Reebok z8 feels like its on an incline even when it's on zero incline
1) readjust the speed sensor, clean it and tight the wires connector well
2) see the block diagram.
3) RUN the software calibration for diagnose, troubleshooting , fix it
4) lube the gear and shift elevation motor.
5) adjust the POT, a little and see if you have a better improve.
6) see the diagram, and proceed
God bless you
Jul 09, 2012 | Reebok Exercise & Fitness
On my horizon ex 79 elliptical the incline bracket and the guide rail do not line up
must be not align, to due some bend. Try to adjust it with some little hammer and fix it.
God bless you
May 15, 2012 | Horizon EX-79 Elliptical
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
Reebok Spacesaver RL is VERY loud...
I had the same problem. Put vasoline on the wheel handle.
No more noise!
Jan 27, 2009 | Reebok RL1500 Elliptical
Reebok RL1500 Elliptical Logo
1,936 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Tony
michael
michael
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
