Question about LeadSinger LS-3000 Consumer Microphone
No power when we plug it in nothing happens it doesnt turn on
  • 1 more comment
  • Anonymous Jan 05, 2009
    i have the same problem and i tried e-mailing leasinger, but they never respond. Leadsinger Customer service SUCKs!!!! Why are they are afraid of proving a phone number.
  • RoboHoff Jan 06, 2009
    Same thing has happened to mine twice now. The first time I cracked it open and found that the card that attaches to the "mother board" was loose. I carefully reattached it to it's port with a snap, put it back together and it worked. Seems it was a symptom of dropping the mic after those power ballads ;-). However, now that trick won't work. No power no matter what I try. There are a few "reset" tricks in the song book you can try.
  • qwickpix Jan 17, 2009
    Same problem. Tried all the obvious and the reset tricks. How do you get it open?
Did you make sure all the song cartridges are installed in the right direction? If they are not, then no power.
Posted on Apr 29, 2009
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Jan 11, 2014 | Acer AL2216W LCD Monitor
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Gateway M275 doesnt turn on
unplug it from the wall, remove the battery, hold the power button down for 30 seconds, then plug the power cord back up and into the laptop and press the power button, if that makes a difference, replace battery and see if it continues to run
Oct 11, 2012 | Gateway M Computers & Internet
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Power light on, nothing happens
Try holding down the power button for several seconds. This will shut down the PC. You should then be able to reboot the system.
Sep 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Boot up problem
Has the power connector at the rear been damaged at all? It sounds like there is no power getting to the laptop.
Dec 29, 2007 | Computers & Internet
LeadSinger LS-3000 Consumer Microphone Logo
270 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
