Question about Fisher and Paykel GWL11 Top Load Washer
Gw709 having problems the water both hot and cold. both at start up only go in short birsts and after 15 secunds or so it shuts down and beeps any help would be appricated pete
  • Anonymous Jan 30, 2009
    I have the same problem, where it starts water is introduced in small bursts then, beeps with four lights on the panel., It is a 7.5 gw709
  • mirandaghea Mar 02, 2009
    Was filling in short bursts before stopping and beeping with some lights on. Followed the tech's instructions to replace the hall sensor and the machine is now fixed. Thank you so much for saving us a packet!!!
Yeh pete .your hall sensor is corroded. unplug the power lead, tilt the machine back & look underneath. unscrew that large white knob & the motor will basically remove. then you will see a small electronic card attached to the windings of the motor (hall rotor sensor). unclip it & unplug. it will be corroded. replace it & reassemble as it came apart. br phil . aussie
Posted on May 13, 2007
My Fisher Paykel GWL 15 will only fill if Hot wash is selected. Should I call a service technician? Thanks Glenn
Try to swap the plugs and hoses to the hot /cold solenoids see if that works the hot valve with cold water if work you need to buy a cold valve.
Jan 24, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel GW709 fill valve problem
the rods have nothing to do with the water level switch. I say check ur water switch with a meter. you may have defective coils, also check the water pressure switch
Mar 21, 2017 | Fisher Washing Machines
Kenmore elite beeps all the time
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE5 Dryer beeps while running
Aug 14, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
Feb 17, 2009 | Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Washing machine not starting
Jan 03, 2009 | Washing Machines
MW051 -U
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped..................
Jun 09, 2008 | Washing Machines
No hot wash
If you shut off cold water the sensor will send message to computerized box the machine will not operate. it shut down the machine.
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
MW051 -U
hi craig Doctr here. there should be a hex head shape on the white knob. get you spanner or socket onto it. give it a crack. will have to check tomorrow about the thread. i can provide you with a new hall sensor. phil
Jun 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
464 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
shaun taylor
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
