Question about Wega Lyra
No water through group head
The touchpad lights are flashing an a WEGA ATLAS ... and nothing works
    Problem Solver:
  • 9 Answers
The flashing lights is a no water error code. check water filter or inlet valve
Posted on Jan 06, 2009
I have problem with my Wega atlas espresso machine. When I turn on the machine water fills up but boiler doesn't heat and pressure doesn't build up. How can this be fixed?
Probably the boiler temperature or current fuse that blew. They are inline with the supply wires and usually clamped to the boiler. Easy and cheap to replace.
Dec 30, 2014 | Wega Coffee Makers & Espresso Machines
Water coming slow
filter plugged or pressure weak.
Dec 17, 2013 | Wega Coffee Makers & Espresso Machines
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Flashing indicator light
follow the next steps and fix it. God bless you
Check Fault Codes
Drain Pump
Touchpad
Jul 06, 2013 | Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
When i put it on the touchpad lights are blinking of my one group head bazzera espresso machine
Hi Id be chekcing the water circuit for the group that is flashing. Flashing lights usually means that there is no water flow. Check for blockages and check the flow meter. If the flow meter is no spinning, the machine knows its not getting water. If all that is good, your pc board maybe faulty. Dazza REPAIRER
Sep 27, 2011 | Coffee Makers & Espresso Machines
Miniwx epu no water coming from group head to cup no water at cylinoid
Since there is no water at the solenoid, then the blockage must be at the metering jet, which sits under the nut on top of the group, turn of water supply and be careful when removing nut do not damaged o-ring if it is not a teflon O-ring, you might have a leak. Clean out jet and filter then reassemble.
Apr 17, 2010 | Wega Mininova EPU Espresso Machine
I have a wega evd1 atlas; and there seems to be some sort of problem with the water not heating up at all. The steam wand is just shooting out water and the water is just coming out at normal temperature....
Hi The first thing I would check is a reset button on the boiler. The next thing would be to do a continuity check or Ohms check on the heating element. If you get no reading you have a bad element.
Jun 13, 2009 | Wega Mininova EPU Espresso Machine
Coffee Makers & Espresso Machines Logo
258 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
