Question about Garmin nuvi 200W GPS Receiver
When charging battery in car
Does unit have to be on, if I only want to charge the battery, or can I leave it turned off while charging?
Thanks
  • 928 Answers
You can leave it off while charging.
Posted on Jan 01, 2009
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Does power switch have to be on when charging with on board charger?
Laptops that I have worked on do not need the laptop to be switched on to charge the battery. There maybe a LED indicator on the laptop to indicate that the battery is charging when the power adapter is connected.
Feb 19, 2012 | Computers & Internet
I neglected to plug in the cord to my cigarette lighter and the charge ran down to 0.I am on a trip and did not bring the charging cord. i tried plugging into lighter in car but it stays on for a feww...
leave it switched off and plugged in.
This would give it chance to actually charge as using it from dead with it plugged in does not always allow some GPS to charge properly.
You neglected to say which brand so its hard to give a 100% answer.
Most GPS should have enough charge withing 4 hours but from dead some older units require anywhere up to 18 hours according to some of the manuals i have laying around
Bob.
Bob
Jun 23, 2010 | GPS
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Battery gradually discharges unless forced to charge
something is wrong withe your lighter so unplug it when the car is off also you may want to do a complete charging system inspection on your vehicle
Jan 06, 2010 | Garmin nuvi 205W GPS Receiver
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
My GPS won't turn on or won't charge
Have you tried replacing the battery.
Wont charge? Sometimes if the battery is totally depleted even the charge light will not go on until the battery reaches a certain level of fill. Are you sure it isnt charging? A new battery will confirm its viability to be able to deliver service in future.
Jul 31, 2009 | Sony NV-U44 GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Charging batteries
Hi Ava, thanks for coming to FixYa.
It is not good to leave your battery on the charger longer than 2 hours. Depening on your battery type, it should not take longer than 2 hours to charge up.
If you leave it on longer than that, it will get too hot, and might make a fire hazard. Also, the hotter the battery gets, it lessens the life of the battery.
Most battery chargers will not automatically turn off, so you should monitor the charging time.
Thanks for coming to FixYa. If you have any other questions, you can leave me a comment.
Namaste
Rob
Mar 25, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
37 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
