Question about Brother MFC-5840CN All-In-One InkJet Printer
Printing fax we have the MFC 5840 CN a fax came in 3 of 16 pages printed and now stuck in printing mode.
  • 320 Answers
Take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Posted on Jan 13, 2009
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Nov 14, 2007 | Brother MFC 8300 Laser Printer
When faxing with brother the mfc 440 cn do you fax with print up or down
Make a copy to see if it copys with the print up or down, the fax works the same way.
Feb 03, 2010 | Brother Office Equipment & Supplies
Prints faint pages
Compare print copy & photostated copy, is there any difference ?
Dec 11, 2009 | Brother MFC-9440CN Laser Printer
Brother 465 CN Won't pring in fax mode
It's all part of the setup that's in your manual. If you use the menu, go to reports and print the user settings you can check if it's set to hold faxes in memory or to print right away. It's all done by user selection.
Oct 02, 2009 | Brother MFC 420CN All-In-One InkJet...
I need the driver for brother mfc 5840 cn for xp
This driver download from internet. Its download link :
Process :
  • first you open the link
  • then type MFC 5840 CN in search list.
  • after searching the particular driver, select it for open the download page
  • download this driver easily
Aug 13, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC 5840 CN
Go here and select drivers>select operating system> Language>seach>more information>download>accept>run. This should FixYa:)
Oct 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
Power it off!
Then goto start>printers&faxes choose the printer that is printing, in the new box that appears click 'document' then select 'cancel'
Normally if the printer was left on it would continue printing several more pages, as these have already been cached in the memory, switching off the printer for a while clears this.
Are you using fax software? Are you not able to limit the amount of pages to be printed? or at least be able to reject an incoming fax that exceeds a set number of pages?
Aug 11, 2008 | Brother MFC-425CN Multi-Function Center...
Brother MFC 5840 Printing
That might be because of generic ink!
This generic ink destroys the nozzels due to a chemical reaction!
If you re lucky you will have good results when useing original brother ink carts.
Run the cleaning procedure twice after you have inserted the original carts!
Jan 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
66 people viewed this question
James Cagle
James Cagle
Jim Keysor
