Question about Hitachi 46W500 46 in. TV/DVD Combo
Is the hitachi 46W500 blue ray compatible
Cannot find HDMI connection point
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Posted on Jan 11, 2009
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
Samsung hitachi sync out of range
take the blue ray disk out, turn your blue ray on and connect to a tv monitor, go to menu, and for hdmi option select 720p then reconnect your hdmi cable to the projector, it should come on, go back to menu, and match the input of the projector to the right type hdmi output from your blu-ray.
there is nothing wrong with your projector.
Feb 20, 2013 | Hitachi Office Equipment & Supplies
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
Blue rays not playing and screen says no signal
This is blue ray lens failure. this optical Assembly has two separate reading lenses. there is one designated for Cd audio and CD_ROM reading and, the other is blue ray compatible. the blue ray lens in inoperable at this point. you will need to replace this lens assembly.
May 27, 2009 | Sony Playstation 3 (PS3) Console
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 46W500 loses video after 10 seconds when connected to motorola HDPVR using HDMI/DVI cable. Works with Yb Yr...ideas?
Check your setup in HDPVR lower resolution to 720P or 1080I or check HDMI cable adaptor or set your Hitachi on auto detection video in MENU
Good luck
Dec 02, 2008 | Televison & Video
Hitachi 46w500
Good Day, reddragon244;
You may not be able to see the cold solder connection, just go ahead and solder both connections on the Crystal.
Good Luck, big IRISH.
Aug 19, 2008 | Televison & Video
No picture on my hitachi 57f500 when i connect hdmi to dvi from new dvd Player
If you have a 2006 or later model, you must set up Blue Ray DVD to Auto Mode on their output setting.
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 46W500 46 in. TV/DVD Combo Logo
344 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
