Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
Time and Temp. display on my JennAir Expressions is not working.
The display on my Jenn Air Expressions is not working.
The time and temperature are not appearing. The oven beeps when selecting settings and heats up for cooking. Everything seems to work except the display. I removed the upper panel and checked to make sure that the connections were good and that there wasn't any damage to them.
  • 1 more comment
  • alicefromoh Jan 01, 2009
    I have the same problem....and am finally trying to find a way to fix it.
  • strike3again Jan 07, 2009
    Found out that I could replace the C3 capacitor with a 100uF
    35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works great now..
    Try this link for more discussion on this topic:
    http://www.fixya.com/support/t139312-clo...
  • 135 Answers
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Posted on Jan 01, 2009
  • jodes6785 Feb 02, 2011
    You do not need to replace the whole circuit board for this issue. I had the same exact symptoms and it ended up being just a capacitor (the c3 capacitor to be exact). This can be replaced and will fix the problem. The capacitor is a 68uf at35v and 105 degrees Celsius. If you cannot find a 68uf capacitor you can use a 100uf cap.
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Light for the temp. & time very hard to see can it be made brighter?
then you will have to replace the eoc the electronic oven control as long as it was working id use it till it wasnt then replace it
Jan 19, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
448 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
