Question about Acer AL1711 17" LCD Monitor
Signal for 10 seconds
Ive just been given a couple of Acer monitors with 2 matching problems, when I switch my monitors on I only get a signal for about 10 seconds and then blacks out and continues to do so, odd times I might manage to keep one on after an hour or so.Any ideas on what it could be? Ive checked my cables - fine graphics card - fine need help !! Thanx , Mark
I know you checked your cables but I had a similar problem and changed the Video card but it was the cable in the end.
Posted on Jun 11, 2007
Hello nicky, double check your graphics card, some graphics card has shorted power causing to shutdown. try to replace or swap a new good condition graphics card. For you to examine well try use to swap it to another PC your Acer monitor. hope this could help you a lot. Good luck. agent1463
Posted on Jun 01, 2007
SOURCE:
Acer M1640 Desktop Acer monitor come up no signal . Have put other monitor it comes up the same
Reset the cmos usualy a jumper, or remove the batery for 10 min, it might be a videocard problem, try another videocard. It might be a memoryproblem.
If you hear bleeds google for biosbeebs and that will show you wich bleeb is what error.
If all else fails change processor and powersuply or finaly the motherboard.
May 02, 2012 | Computers & Internet
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1714
OK I have the same monitor, I was given it by a client when I couldnt fix it, I DO have the 19V supply and still getting the same problem.
If you open it and reseat all connections you can reach, I find it starts to work. Unfortunately after less than a few days use it goes off again.
Hopefully this can help someone get further
Apr 14, 2007 | Acer AL1714 17" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
