Computer is dead will not power up
Took computer in to service tech he told me the motherboard was fried
  • 1 more comment
  • pantion_bf Jan 03, 2009
    ขอบคุณคับ
  • srkeller1966 Feb 02, 2009
    Had a password in the bios that I could not remember, took the battery out to clear the cmos, replaced the battery and press the power button and nothing. The leds on the motherboard are on, so I disconnected all components to the bare ones needed. Press the power button and nothing, no fans no beeps nothing. Any ideas why taking the battery out would do this?
  • Jeff Parker May 11, 2010
    need a little more information than that. What happened before it died? When you say it will not power up what exactly happens when you push the power button (Do the fans spin at all? Do any lights come on? Are there any beeps or other noises?)? Your description indicates that the problem is likely the Motherboard, CPU, or power supply but it could be other things as well.
I have Nokia Cell phone 6070 which is Sofware Completly Walk out (Remove) Should you tell Me about what is problem ansd what Divece are atteches within.
Posted on Jan 03, 2009
Will not power up
This is a common problem with Emachine motherboards, the problem is the power supply is a best tech and allows voltage surges to the motherboard which fries it too. If available you usually have to replace both the power supply and motherboard. I do not know what exactly goes bad on the motherboard but I have replaced many emachine power supplies and motherboards. The motherboard kit which used to be available from Emachines included a power supply and no warranty if you didn't change the power supply. They knew they had a problem.
Dec 27, 2009 | E-Machines (308714) Motherboard
I recently dropped my HP Compaq Presario laptop V5209US and took it to Fry's electronics for diagnostics. I wasnt able to open the CD door after it was dropped. They told me it has a ''bad optical drive...
If everything else was working fine (until today) and just the cd-drawer would not open, a damaged systemboard (or motherboard) is highly unlikely.
1) What does "not turn off"? The Laptop or the CD drive?
2) To check what is exactly damaged you could power down the laptop and remove the CD drive entirely. Then power on the laptop. If everything works fine only your cd drive was damaged.
Jun 30, 2017 | Computers & Internet
No power
Could be you power supply... try one from another machine.
Apr 04, 2009 | Gateway 3250S PC Desktop
No power
Just open ur P.C cabinate and look when the Power supply is on in ur mother board then there is a green light in ur Mother board ; is it on ??
If the LED is on then I hope ur mother board is ok yet.
Then I think there is some connection prob on the pushing button on the cabinate.
Check it if it is not then u have to replace ur mother board.
Jan 02, 2009 | Gateway 3200XL PC Desktop
Computer is dead will not turn on
When you buy a new motherboard, make sure and get one that accepts the same processor and memory, and video card that you have now. It is not terribly complicated to replace the motherboard but if you have never done it before be prepared to spend a few hours reinstalling your operating system and all the correct drivers for the new motherboard components. Also make sure you get a board that will fit in your computer case, not all boards are the same size.
Dec 31, 2008 | Gateway Computers & Internet
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computer problems
it sounds more of some legal issue than a technical one.. ask someone in that field..don't waste my time.
Aug 22, 2008 | Intel Motherboard
EMachine Help
If you took the pc in to a repair shop and they diagnosed that as the problem. You will have to install the new vieo adapter in the computer. Then plug in the monitor to see something on the screen. You can go into the bios to disable the other. Now if you are going by hear say and an actual tech did not check your system it does not necessarily have to be the video adapter at fault. You will need to have it checked out to validate that. Now if you did install the card you will have to plug the monitor in the new adapter. If the problem is still there you have another issue with the pc. Please comment on what the case may be. I would be able to better help you.
Hope this helps you
Oct 20, 2007 | E-Machines T6528 PC Desktop
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
