Question about Microsoft PowerPoint 2003 Student & Teacher Edition (yl800055) for PC
Powerpoint 2003 music won't play over slides
I've followed the directions to play music and it will play on the first slide when I press play sounds under the custom animation tab. However, no music will play either on the first slide or on any other slide when I click on view slide show. It can't be the song because I tried it in the WAV format as well as WMA. I've also tried using a song I used on another presentation I made which worked on the entire thing. I have tried everything and I'm completely stumped.
  • 1 more comment
  • elwoodblues6 Jan 01, 2009
    No. I used a song I used on a different presentation. The song works on the other presentation but the same song doesn't work on the one I'm struggling with. Nothing else works either.
  • elwoodblues6 Jan 08, 2009
    Thanks. At least I'm not the only one with a problem! No sound file works with this presentation, but I used the same sound file on a different presentation, and it worked.
  • Richard Thorgeirson
    Richard Thorgeirson May 11, 2010
    So... if you use a different sound file with this presentation it works OK?
  • 80 Answers
Using music in power point is a nightmere. If you can just avoid doing it altogether. I suggest using movie maker if you just showing a slide show. I have made power point to work using some music but it does not always work. I spent alot of time trying to make it work and have come up empty all to often.
Posted on Jan 08, 2009
Music in power point presentations
  1. Display the slide to which you want to add music or sound effects.
  2. On the Insert menu, point to Movies and Sounds, and then do one of the following:
za079005000.gifInsert a sound file
za079005000.gifInsert a sound clip from Clip Organizer
  1. Double-click the sound file that you want to insert.
  2. When a message is displayed, do one of the following:
    • To play the music or sound automatically when you go to the slide, clickAutomatically.
    • To play the music or sound only when you click the sound icon za006052183.gif, clickWhen Clicked.
  3. To adjust the settings for when the sound file stops, click the sound icon za006052183.gif, right-click, and then click Custom Animation.
  4. In the Custom Animation task pane, click the arrow on the selected item in the Custom Animation list, and then click Effect Options.
  5. On the Effect tab, under Stop playing, do one of the following:
    • To stop the sound file on mouse-click of this slide, select On click (the default).
    • To stop the sound file after this slide, select After current slide.
    • To keep the sound file playing for several slides, select After, and then set the total number of slides the file should play on.
Mar 24, 2011 | Microsoft Windows Vista Home Basic Edition
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
Jan 16, 2010 | Microsoft PowerPoint 2003 Student &...
Linking sound wave files to PowerPoint
Hi Rose,
Instead of copying presentation directly to CD, simply do Package on CD (File menu --> Package in CD, then copy to a folder or directly burn to CD
it will contain everything required to run presentation your PPT file, Powerpoint Viewer and all supporting files.
any ways having problems pl contact me
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Mar 13, 2009 | Microsoft PowerPoint for PC
Changes from slide to slide
it's likely that the rest of each slide is not exaclty equal (e.g. the amount of text) which could push the picture a little bit in one direction or another or make powerpoint automatically resize the picture or text objects to fit the slide. I'd have to really see the slide presentation to be 100% sure but orientation on each slide is likely the cause.
Mar 03, 2009 | Microsoft PowerPoint 2003 Student &...
Hello, i am from sikkim and i want to know or my question is that once i made a powerpoint slide and add a music in my slide as well i save the file in .pps .but what happens is that i send that slide to...
This is because if a music file is larger than a certain size (cannot remember the exact size, but relatively small) the music is not saved in the PP but in the original file. you should send the music file together with the presentation
Jan 24, 2009 | Microsoft Office Professional 2007 Full...
Adding music to a powerpoint presentation
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
Dec 03, 2007 | Computers & Internet
Using powerpoint to add music on slides
i want to edit music on my slides. i want one track/sound to play through all slides
Oct 23, 2007 | Microsoft Office Professional 2007 Full...
Microsoft PowerPoint 2003 Student & Teacher Edition (yl800055) for PC Logo
718 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
