UE sign on machine not spinning
SOURCE: samsung b1445v front load washing machine will not pass prog. 8 even when empty, then code ue
This is an error caused by the cycle advance which acts like a timer. The main control board can cause this issue. Diagnostic testing will need to be performed to determine the cause of this problem
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E. 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
SOURCE: Hi why does my machine
Hi UE error in Samsung washer indicates unbalanced load. You can try to leave it unplugged for few minutes to solve this issue or press and hold START/PAUSE button to reset this error. Please let me know the model# if you need more help. Daniel
