Question about Compaq Presario 700 470024-192 Notebook
Can't talk When I log on, my homepage comes up OK...but when I tag someone this message comes up "Windows live Messenger has stopped working" Then they say if they identify the problem they will let me know (never do). I have tried uninstalling and reloading IM, that didn't work. Also I always have to shrink the home page to get to the conversation window. This started after I got an off line email...couldn't open it or delete it...
I cant insall windows messenger in mu computer acer aspire one
Have you gone to the windows messager website and tryed to install it that way? If it wont let you download, Try installing Windows Live Messenger, or even Windows Live Messenger PLUS. If those are still not working for you, You can log onto through Meebo.com and still chat with your friends.
Jun 03, 2011 | Windows Live Messenger
Can not log on to windows live messanger
Hello.
Are you trying to log-on to the messenger on the PC or mobile?
Mar 08, 2010 | Microsoft Windows Live Messanger
When i logged in to my msn,i'm unable to chat, as soon as i open a window to start a chat my system log me out saying there's a problem with windows
Check your firewall isn't blocking msn try this
close MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Hope I helped Dr Reed
Jan 28, 2010 | Microsoft Windows Live Messanger
Last night I had a message box pop up when I tried to log in to msn messenger,saying that I had to update to the latest version,although I tried to ignore it and log on I was unable to continue. So I have...
What I would do is go to control panel and click on the firewall and see if it is stopping you. If that does not work I would contact the Live IT sipport and see if it is on their end. Thank you for using Fixya
Nov 06, 2009 | Microsoft Computers & Internet
How could i get in my msn messenger when i forgot
If you are sure somebody highjacked your MSN account, the first option is to contact MSN support team As Soon As Possible.
If you can't wait, take a try of this password recovery software. It will help you recover forgotten login password for Chat Messengers like MSN Messenger, Windows LIVE Messenger, Google Talk etc. Good luck!
Sep 29, 2009 | Microsoft Windows Live Messanger
Missing my messenger icon
same happens with me, only i had another laptop with windows live as a shortcut, i pasted it onto my sd card and the put the sd card into my laptop without messenger, clicked the shortcut and it started working again
Jun 07, 2009 | Yahoo Messenger
All my contacts are missing from my contact list
This is what MS told me to do..but did not work. Finally they told me to use 8.5. Try if it helps you.
Messenger Connectivity Log & Contacts Log
A. Delete the old log files.
Right-click the Start button and then click Explore. In the window that opens, click Folder Options on the Tools menu. Click the View tab, and then make sure that Show Hidden files and folders option is selected.
1. Click Start, click Run, type %userprofile%\Local Settings\, and then click OK.
2. Double-click the Application Data folder, double-click Microsoft, and then double-click Messenger.
3. In the Messenger folder, look for the MsnMsgr.txt file and delete it.
Note: If you get an error stating that you cannot delete MsnMsgr, please make sure that Windows Live Messenger is not running on the background. To check this, open the Task Manager window and check whether the msnmsgr.exe is running on Processes. If it is, select the application and click End Process. If you are prompted, click Yes.
To open the Task Manager: Click Start and then Run. Type taskmgr.exe and click OK.
4. If you don't see the MsnMsgr.txt file, please proceed to step B to enable the connection logging.
B. Turn on connection logging if the feature is not yet enabled.
1. Start Windows Live Messenger but do not sign in.
2. On the Tools menu, click Options.
3. In the left navigation bar, click Connection.
4. Click Advanced Settings.
5. Under Connection Logging, make sure that the Save a log of my server connections to help troubleshoot connection problems check box is selected.
6. Click OK.
C. Try to sign in to Windows Live Messenger again to replicate the error or issue being encountered with the service. A new connectivity log file, MSNMsgr.txt, is created the moment a sign in attempt to the service is made. When errors or issues are encountered, the connection logging feature will capture their logs.
D. Access the newly generated MsnMSgr.txt by following the steps in step A. Please look also for the ContactsLog.txt file. Please attach the files on your e-mail response to us.
Copy of the Windows Live Contacts folder
The Windows Live Contacts folder can be accessed on this path:
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts
Note: Windows Logon name is the logon name that you use to sign in to Windows.
Right-click the Windows Live Contacts, select Send To, and then select Compressed (zipped) Folder. A compressed file is created in the same folder. Please upload the file to Windows Live SkyDrive and we will retrieve the file from there.
To access Windows Live SkyDrive, please do these:
  1. Open your Internet browser and visit http://skydrive.live.com.
  2. Sign in using your Messenger ID and password.
  3. Click on the Public folder.
  4. Click Add files and locate the zipped Windows Live Contacts folder. Upload it.
  5. Once the file is successfully uploaded, please send us the URL or link on your e-mail response so we can download it.
While we are working on this issue, we suggest that you temporarily use the earlier version of Windows Live Messenger (v8.5) so you can continue to communicate with your friends. Please note that to be able to install the previous version, you need to uninstall all the Windows Live Essentials programs (i.e. version 2009 of Messenger, Mail, Photo Gallery, etc.).
1. Exit Windows Live Messenger.
2. Click Start, click Run, type appwiz.cpl and press Enter
3. On the Add or Remove Programs window, click on Windows Live Essentials, and then click Uninstall/Change
4. Select Uninstall, click Continue.
5. Under Select the programs you want to uninstall, check all the Windows Live programs shown and then click Continue.
Windows Live Messenger 8.5 can be downloaded from:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
Apr 29, 2009 | Microsoft Windows Live Messanger
IM keeps logging me out.
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope this helps
Chris (ziraffa)
Nov 11, 2008 | Microsoft Windows Live Messanger
Contacts missing from my contacts list
Hello from Portugal,i used to have the same problem,when i logged to msn no contacts although in hotmail they where all there,so i uninstalled windows live essencials(all programs) then downloaded windows live messenger 2009(again) but this time i only installed the messenger app!problem solved now when i log in all my contacts are there and the messenger works at is full power(lol) hope i helped someone and sorry for my english!
Nov 10, 2008 | Microsoft Windows Live Messanger
Windows live messenger and Yahoo messenger has stopped working
you can have as many IM's as you like installed, although i would only use 1 at a time, try doing a java update and reinstalling live messenger, then do a microsoft update
Oct 29, 2008 | HP Pavilion DV5234US Notebook Laptop
Compaq Presario 700 470024-192 Notebook Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
