Yamaha DTX-MULTI 12 DRUM PAD Logo
remberto Posted on Oct 15, 2012
Extraer los sonidos de la yamaha dtx-multi 12drum pad
1 Related Answer
Fred Yearian
  • 5603 Answers
  • Posted on Apr 03, 2010
SOURCE: Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Yamaha DTX Multi 12 Electronic Percussion Pad volume controller not working properly. What is the problem please?
Question edited for clarity, full 'make model (what it is)'.
Question moved from Television and Video.
Get in behind it and spray it with Electrical Contact and Switch Cleaner.
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Hi Ezra, for the failure you describe, you may have a problem with the Main Insert connectors, more presumably on the left, this connector has the function of interleaving some type of processor in the stages of the master L and R, and has some contacts internal that get dirty and produce false contact in the passage of the output signal
Try cleaning it with some contact cleaner, put a small amount of cleaner and with the help of a plug, put it on and take it out several times in order to make the cleaner work, do the same with the right channel, because the same fault will appear. , sometime
If this does not work, you would apparently have problems with the left master dimmer potentiometer on the corresponding electrical circuit
I sent you the link to download the user manual of your Behringer
I hope you serve my suggestions and manage to make the left exit work
Greetings Franco Dosil
Hola Ezra, por la falla que describes, puedes tener un problema en los conectores Main Insert , mas presisamente en el Izquierdo, este conector tiene la funcion de intercalar algun tipo de procesador en la etapas de los master L y R, y cuenta conunos contactos internos que se ensucian y producen falso contacto en el paso de la se?al de salida
Prueba limpiarlo con algun limpiador de contacto, pon poca cantidad de limpiador y con la ayuda de un plug ve colocandolo y sacandolo repetidas veces a los efectosn de que el limpiador actue, haz lo mismo con el canal derecho, porque ya le aparecera la misma falla, en algun momento
Si esto no da resultado, aparentemente tendrias problemas con el potenciometro atenuador master Izquierdo on el circuito electrico correspondiente
Te envio el link para que descargues el manual de usuario de tu Behringer
Espero te sirvan mis sugerencias y logres hacer funcionar la salida Izquierda
Saludos Franco Dosil
http://www.manualsbase.com/es/manual/downloadmanual/119881 https://manualsbrain.com/es/manuals/809021
3helpful
3answers
Http://music.yamaha.com/registration
soy usuario de un teclado yamaha y queria saber si me pueden enviar las partituras de iniciacion al teclado. gracias mi nombre es Pedro Guardia Berrueco. Mi direccion de E.MAIL: [email protected]. el modelo es psr-E223-YPT-220
Jun 05, 2012 • Music
Quiero conectar la guitarra
Se necesitan dos cuarto de pulgada a los adaptadores de RCA. El uso del adaptador, conectar la guitarra a la entrada y la salida a su amplificador o dispositivo que desee.
Por favor, perdone mi espa?ol, ya que no lo hablan.
2helpful
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
3helpful
Como puedo conectar mi Consola Peavey de 32 Fx en mi mac OS X 10 y tengo instalado Pro Tools M-powered y pro tool HD necesito que me reconozca los 32 canales para poder grabar en multipista.
Necesitas los drivers que deber?an venirte en un cd con la consola. Si no instalas eso, la PC no reconoce los AD converters que usa cada canal , que ser?a como agregar la misma cantidad de tarjetas de sonido nuevas, y es imposible que puedas grabar.
Si no tenes el CD, deber?as ingresar en la pagina del fabricante para descargarlos.
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
