Question about Syntax Computers & Internet
My Syntax S635MP motherboard can't take more RAM
I bought a computer from my boss about a year and a half ago which he built himself. It only had about 256 MB of RAM (total) on it so I decided to upgrade. I opened it up to get the original RAM chip and look at the motherboard (which I discovered is the SYNTAX S635MP model), then proceeded to go and buy the appropriate RAM chips for it. When I got the chips (two of them at 512 MB each) and installed them, my computer had a nervous breakdown and slowed to a dead crawl! (If that!). When I installed just one of the chips, my computer worked just fine. Is it a problem (as I have heard) with my processor speed? If so, what then is the solution? (I have Windows 2000 professional as an operating system, and have noticed that BIOS is dated at 2003 when I see it in the start-up information).
  • myattacksubs Jan 01, 2009
    Chiploon, thanks for trying but it really has nothing to do with the RAM chips which I purchased. (Nor with the one which came with the computer). Both new chips worked just fine, and obviously, there was could not have been anything wrong with the original as I would not have had any RAM to start with at all if there were. Also, as the computer could only take one chip of RAM (they were 523 MB each), I took the other back to the store and got a refund. No, this either has something to do with processor speed (which I read on another forum) or something else entirely, and I am just trying to use the process of elimination to find out what it is. Thanks for the effort, however.
  • 32 Answers
It is highly probable the the other chip ( also known as Memory / RAM ) is faulty, hence causing the system to stop working.
Take out the working one and put in the other RAM. if the system does not startup, it is the RAM issue.
Nothing to do with BIOS or Windows 2000.
Posted on Jan 01, 2009
  • Chip Loon Ng
    Chip Loon Ng Jan 01, 2009
    Thank you for the clarification. :)
    Based on your detailed description, a BIOS update maybe required to bypass the RAM limitation.
    However Syntax does not support anymore for this board.
    Processor should not be a problem. If it is, the system cannot even start up.
The bios is not the problem either there was a problem with the poolers on the s635mp boards and you check this post http://www.bluesfear.com/forum/index.php?showtopic=16506 i have the same board and it was fine for awhile then blue screen here we go
Posted on Jan 20, 2010
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
I have a Dell Latitude D600 struggling to boot
I had the same problem as you with two of these D600's. I'm pretty sure it's not a RAM issue, more likely a problem with the motherboard. I reckon it's time for you to get a new one .. i did!
Sep 24, 2009 | Dell Latitude D600 Notebook
Dead computer
It sounds like your power supply may have failed. If you have another computer handy, try connecting its power supply to your dead board to see if it springs back to life.
May 05, 2009 | Syntax SV266M Motherboard
Syntax sv266m motherboard....it wont go past the windows xp scree
check if the safe mode is working..?pressing F8 just b4 windows xp screen comes up...
if yes then good...
check if u seated the ram properly?.and check if its showing the full amount of ram in the bios page..
Mar 04, 2009 | Syntax SV266M Motherboard
Adding a video card
if you have a video VGA plug on back of your computer and it is not an added card, then it is built in. You can disable most on-board video via settings in the rom bios.
Jan 24, 2009 | Syntax Computers & Internet
Drivers for Syntax SV266AD Motherboard
I stumbled across a site awhile ago with all of the syntax mobo stuff. It's not active anymore, but the archived version seems to be pretty complete.
http://web.archive.org/web/20061105180703/http://64.168.125.230/support/SyntaxDownloads/
Aug 18, 2008 | Syntax SV266AD Motherboard
Syntax sv266a
Jul 28, 2008 | Syntax SV266A SKA KT266A Motherboard
Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Sep 26, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Syntax motherboard
I'm sorry but the processor is binded to the motherboard and cannot be upgraded. See for yourself: http://www.tigerdirect.com/applications/searchtools/item-detailsInactive.asp?Sku=S452-1001
Apr 03, 2007 | Syntax S746FX Motherboard
Computers & Internet Logo
524 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
