Question about Lakewood Oil-Filled Electric Radiator Heater
Model 5700/7 Radiator heater won't work
Heater smelled like plastic was burning. Shut off the heater. Now light won't come on. Plastic on quick connectos to small switch (dime sized in diameter with two terminals) at the bottom of heater were burned. How can i test this switch to see if it's good.
  • 57 Answers
May be safer to return the heater if it is new. You would not want to risk a short and/or electrical fire.
Posted on Jan 04, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Why does my car smell like plastic melting when the heater is on?
you have an electrical short,take to a mechanic NOW before you burn up in your car
Apr 09, 2015 | Cars & Trucks
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
Should radiator hoses be easy to squeeze
I have an older Chrysler Town and Country but I had the same problem, I found mine to be a leaking radiator, check all of your hose connections and if you have the flimsy plastic radiator in your van, get the more expensive aluminum version. The plastic radiator melts at the bottom because the are required to be grounded and sometimes this is not done properly, therefore sending an electric current through the radiator melting out the bottom, went through three of these before anyone let me know that they had to be grounded. If there are no leaks under your radiator or hoses, the next thing I would check is your cylinder head the burning smell could be dripping from your head to your exhaust. I would say you have a nice sized leak some where because with these vans if you do not have enough coolant in them they will not produce hot air fill your radiator up with more coolant and then test your heater, it should work but until you find the leak I would make sure to keep extra water/coolant inside the van.
Mar 25, 2013 | 2006 Chrysler Town & Country
1999 expedition- After driving for a half hour or so the engine smells like a faint burning smell but the temp. gauge inside reads normal. I also can not get any hot air to come out with the heater on even...
No heat usually means low water level in radiator. Check your plastic surge tank to see if is at the proper level. When engine is cool check actual level in radiator.
For smell check to see if any oil is weeping from top engine gasket and dripping onto exhaust manifold, You should be able to check with flashlight while engine is idling.
Nov 23, 2010 | 1999 Ford Expedition
When I turn the heater on burnt plastic smell from vents
It could be your heater blower motor or the blower speed regulating reisitor.
Try different blower speeds, see if the smell goes away. Also if one or more speed setting don't work, it is more than likely it is the resistor, if no to the tests, it is more likely to be the blower motor.
Also check to see if the blower intake is blocked.
Mar 02, 2010 | 2007 Chevrolet Uplander LS Minivan
Strong ''burning plastic'' type smell coming through heating ducts.
it sounds like you have a main air movement system motor that is burning out. it will probably quit on you in the next few days. likely cost to repair from company 375-700 somtimes more if you have a variable speed furnace, in which case you should consider replacing the whole furnace for what it would cost for the motor on one of those.
Sep 08, 2009 | Heating & Cooling
Grinding noise from Heater and burning smell from 1997 Dodge Cara
the problem could be in the blower wheel or motor, is there a vibration with the blower on and grinding. i rec removing blower motor and inspecting that further. debris could be cought inside it or blower may need replacing. it may not be that bad of a repair $$.
Nov 15, 2008 | 1997 Dodge Caravan
Grindin noise on My 97 Dodge Caravan when heat is turned on .
yes,could be something in there rubbing against fan cage.
Heater Has Bad Odor
You are meant to run them for two hours on full power at first in a well ventilated area to get rid of the packing salt - This really helps.
However, I have returned three of these as they are defective.
Mar 01, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
Lakewood Oil-Filled Electric Radiator Heater Logo
123 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
