Question about Konica Minolta MAGICOLOR 2300W LASER Printer
Magicolor 2300w Toner transfer problem
My toner wont leave the transfer belt and go onto the paper .
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your concern on a Konica Minolta MAGICOLOR 2300W; no printout/toner left in transfer belt. Offhand, a few ideas you may want to consider, explore, try or check:
  • error message(s);
  • PC Drum Charge Corona.
The best and correct procedure would be to follow the checklist as detailed in the Service Manual.
Good luck and Thank you for using FixYa.
Posted on Jan 08, 2009
    Sergeant:
    Novelist:
  • 326 Answers
The pressure roller of ur machine is faulty and needs to be replaced to create pressure on the paper to transfer the toner on it.
Posted on Dec 31, 2008
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
There is no error message but the pages come out very weak and the more copies you make the lighter they become
Might be one of these things:
If somebody reset a cartridge back to say it is full at 100% full and the toner is actually running out.
Or you might have a problem with your Transfer Belt, my Transfer Belt on magicolor 2300w was printing weak and faded, as if the print was washed out looking, after a bit of research I removed the Transfer Belt and cleaned it with ISOPROPYL ALCOHOL (it's almost 100% alcohol), replaced the same transfer belt unit and it prints fine again.
Oct 14, 2009 | Minolta magicolor 2300W Laser Printer
Konica 2300w jams paper on the fuser unit.
the lubrication for the fuser roller comes from the KM toner. There is usually a cleaning roller in the fuser as well that distributes some oil. Another thing that could cause the problem is non-recommended paper like heat transfer paper, inkjet photo paper or very thick paper. Make sure the fuser sperator teeth are still in place. Lift the two green levers and pull the black cover back. You should see three light brown teeth hovering above the fuser roller. There are some black ones on the guide as well. These are supposed to detatch the paper from the roller incase it sticks.
Aug 05, 2009 | Minolta magicolor 2400W Laser Printer
Replaced Black TOner but still says it is empty
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Jan 26, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Toner will transfer to the transfer be
As I understand it from servicing laser printers, the toner is actually drawn statically to the paper from the drum by a charge on the belt. Toner is not supposed to be distributed to the belt. The fuser fuses the toner to the paper after the transfer. Can you access the fuser rollers to see if there is any sign of wear or damage they may be keeping the paper from entering it properly? The toner on the belt is probably excess from the paper not being pulled through and having the toner fused properly.
Dec 31, 2008 | Konica Minolta magicolor 2400 Laser...
Won't transfer from the transfer belt to the paper
Where is the Transfer roller. was that replaced also when replacing the transfer belt ITS a SPONGE LOOKING ROLLER same lenght as the width of the belt
May 03, 2017 | Konica Minolta magicolor 2400 Laser...
Laser printer
I developed a color print that has all 4 principal pure toner colors in vertical and horizontal bars that are at least 2" wide.  If perhaps you are having a toner problem only one of the colors will be affected.  If all colors are affected there are two possible issues.  The drum, which I think is actually a belt, and the other the fuser assembly.
The fuser is a heater and pressure roller system that presses and melts toner onto a page.   The drum is an imaging device that picks up toner where images should be and transfers toner onto a piece of paper.  Any toner not transfered from the drum / belt is destined for a waste toner hopper.  If the belt is not being cleaned properly or has an image or flaw artifact that cannot be cleaned / erased you always get that printed on a page.
Aug 04, 2008 | Konica Minolta magicolor 2400 Laser...
16H means, that the transfer belt does not rotate correctly, open all covers, remove any paper, whats stack inside, remove waste toner box, drum unit then open 2 nipple screws and pull out the transfer pelt, if the belt looks ok, reinstall everything and power on again. if works, then everything is ok, if not, then there is something wrong with TBU or TBU
Nov 14, 2007 | Minolta magicolor 2300W Laser Printer
Open Questions:
124 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
