Question about SanDisk Sansa e200 MP3 Player
Sansa 200E keeps turning off
New battery
have check all things that would make it turn off automatically
  • 40 Answers
Reformat your sansa then go to www.sandisk.com and search the site for the firmware for your mp3 player.
Posted on Jan 01, 2009
My sansa mp3 only begins to turn on when i connect it to the pc but then freezes when it says 'Sansa m250 2.0 Gb' please help
Look further than the batteries. Take the whole thing apart. That's what I do, and I've fixed a lot of things. And keep looking on the internet. A few hours of looking can result in years of listening.
Jun 16, 2012 | SanDisk Sansa m230 MP3 Player
Battery will not charge
Battries may require replacement.
Jul 12, 2009 | SanDisk Sansa Clip MP3 Player
Dead battery?
Both. It has an automatic shutoff - it can be changed in the settings menu - AND it could possibly have a dead battery. Do yourself a favor - before you ask any more questions, download a full user's manual from Sandisk's website - they are the manufacturer of your player.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa m240 MP3 Player
My Mp3 player keeps turning on repeatedly
Try unscrewing the back and taking the battery out for a minute and replace and see if that helps.
Aug 07, 2008 | SanDisk Sansa e250 MP3 Player
Combo of: "reading", "writing", "disconnected", "low battery", turning off by itself
why doesn't anyone ever call the hotline?
-Tha Mp3 Doctor
Jul 13, 2008 | SanDisk Sansa Clip MP3 Player
SANSA 250 E BATTERY
I found that Best Buy has an MP3 help line number, they were very helpful and solved the problem quickly. The solution was to hold the menu button for 20 seconds, this resets the program and the sansa turned on automatically.
Mar 03, 2008 | SanDisk Sansa e200 MP3 Player
Frozen
Mine froze in play position, but no sound.
Here's what worked for me. Mine is the Sansa M250
1)Plugged the player into the PC and removed all the MP3s
2)Downloaded update program from Sansa link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
3) Install the program
4) Plug the Sansa into your PC.
5) Program automatically starts and allows you to check for software update. Do so and let the program update your player.
Fixed my freeze problem. Player working perfectly now.
Hope this helps.
Dec 05, 2007 | SanDisk Sansa m250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
When turning on screen fades away then restarts automatically
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
85 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
