I have just installed a crucial x1600 pro graphics card,when i fired up the computor the monitor displayed multi coloured vertical lines and a box appeared saying it was in analog mode, how do i configure the targa visionary monitor to digital mode. regds A Gough
  • Thomas F. Schneider May 11, 2010
    Did you install the software and driver for the new video card?
  • 3 Answers
I'm assuming "it" is the monitor rather than the video card, and that you are using some flavor of windows as your operating system.
1. Digital vs Analog mode is determined by the cable input plug on the monitor that use. Your cable from the computer to the monitor must be a DVI cable, and must connected to the DVI plug on your monitor. It must also be getting a digital signal from the video card, so must be connected to the DVI output plug on the card. You can use an adapter to convert from DVI video card output plug to an analog cable, but not the reverse. For a digital monitor, you must have a DVI cable. DVI connectors come in different flavors, so be sure to read specs for the video card and the monitor to choose the correct one.
2. As already suggested, it also sounds like you may not have installed the driver and video control software that came with the card. Windows will attempt to install a new video card. If you don't stop it, you can get what you see. So boot the computer in safe mode which should get you some kind of display, then install the software from the CD that came with the board. reboot, Once you are running, check for software updates on the support web site.
Posted on Jan 01, 2009
  • 122 Answers
Change cables on card you should have two ports on the card one for analog and one for digital and the cables are different check the ends of the cables digital and analog are different configuration.
Hi i installed a asus graphics card in my computer...i loaded in the install cd..all went fine till the asus enhanced display driver annonced "no hardware found"...please help
Make sure your computer is updated with latest service pack...
Manually explore the driver cd and try installing any patch files supplied along with the drivers...
Also check for any service packs in microsoft site...
Nov 26, 2010 | ASUS RADEON X1600 Pro 512MB DDR2 Graphic...
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Card works in vga mode before installing 9-3_1_legacy_xp32-64_dd_ccc.exe After installing, video fails; displays only distorted flickering lines.
Restart your computer.
Tap on "Delete" until the BIOS comes up.
Look for an option for "VGA mode", as I wouldn't know what your BIOS is, you'll need to look carefully.
When you find it, shut it off, save your options then restart computer.
Comment if this didn't work, I can help you further.
If this helped, please vote and have a good week!
Jul 16, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
CANNOT FIND GRAPHICS CARD INFORMATION
Reinstall. Go to www.ati.com and select the driver for your operating system. They use a one driver for all cards approach
Apr 26, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Duel Monitor Problem
first thing first ensure that you have the latest ATI radeon X1600 pro driver and software installed else you won't be able to get the desired options for dual display under settings coz it will be working with generic drivers.
To download the latest driver and software click here
Then please click the following link :
ATI Radeon X1600 PRO How to
On this link click on the option
  • "Guides, Walkthroughs and "How to's"
Then opt for
  • "How do I use dual displays or TV/HDTV out? "
Just follow the instructions.
Feb 19, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Monitor display blurred by vertical coloured lines
connected another monitor, still same problem ,must be graphics card ! THIS proved. to be the case as replacement has solved problem
Aug 05, 2008 | Computers & Internet
Lost driver
ATI display driver
Here is ATI multi driver: Click to Download
From AMD: "This is he ATI Radeon Catalyst Display Driver version 7.10 For WindowsXP/MCE, released by Advanced Micro Devices(AMD). This release updatesthe AMD Display Driver to version 8.401, supports all Radeon Desktopproducts(ATI Radeon9550/9600/9700/9800/X300/X550/X600/X700/X800/X850/X1300/X1600/X1650/X1800/X1900/X1950/HD2400/HD 2600/HD 2900 XT). This unified driver has been further enhancedto provide the highest level of power, and reliability."
Jul 29, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
