Question about Microsoft Windows XP Home Edition
Computer I installed a game Ithink that i hit somthing that has made my keys stick. I mean when I type I have to hold the key down for 2 seconds befor it shows up on my screen could you help me please
    President:
  • 949 Answers
Uninstall the game,and see if this helps,,if it does not it is the keyboard,,,they run about 4.00-100.00
Posted on Dec 31, 2008
When first starting to type the first key sticks and types same letter 7 times.
Open Keyboard in Control Panel
on the speed tab make changes
To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delayslider.
o adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
Apr 24, 2013 | Computers & Internet
Tip
How to Reset Parameter RAM (PRAM) - Macs
Resetting Parameter RAM (PRAM)
PRAM stores certain system and device settings in a location that Mac OS X can access quickly. Exactly which settings are stored in the computer's PRAM varies depending on the type of computer as well as the types of devices and drives connected. To reset PRAM:
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step 4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5.Hold down keys until computer restarts, and you hear startup chime a second time.
6.Release keys.
on Mar 01, 2011 | Computers & Internet
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
I forget my password plz help me
You will have to reinstall whatever Mac OS X system you were running by inserting the disc, then shutting down the computer, restarting the computer while you hold down Apple button + C. This will begin the installation process and you will start from scratch. You will most likely lose all of your old information.
If you want to keep all of your files and try a quicker but a little more trickier process. Create a new Admin user account to override your forgotten password account, here is how:
1. Turn on your computer When the computer chimes press and hold Apple button + S The screen will be black with white text
2. Type the following: /sbin/mount -uw / Hit the Return Key
3. Type: rm /var/db/.applesetupdone Hit the Return Key
4. Type: reboot Hit the Return Key
Once your computer has restarted use the Setup Assistant to create a new Admin User account and you can delete your old account while saving all of your old files.
Mar 06, 2011 | Computers & Internet
I tried to renew my Webroot AntiVirus with Anti-spyware. I ran into a compatibility issue with vista. I uninstalled both the firewall and antivirus, thinking this will help, and now I can not install...
HI There,
I recommend that you use Sytem Restore to go back to a point before the problem began.
1. Click the Start Button
2. Select All Programs> Accessories> System Tools and click on System Restore.
3. Select a point before you tried to install/renew your antivirus and restore to that point.
Your description of what you were trying to do was not completely clear to me so I have to guess. If you were trying to install a different product than Webroot, then you need to completely uninstall Webroot BEFORE you install a different anti-virus.
Also, after uninstalling Webroot, hold down the Windows key on the keyboard and press the R key. A run window will appear. Type in %temp% and hit enter. When the Temp File window appears hold down the ctrl key and hit the A key. All temp files should now be highlighted. Hit the delete key. A message may appear saying Windows cannot delete a file because it's in use. This is normal. Check the box in that window for Skip All similar files and hit ok.
Reboot your computer and then install the new Antivirus.
Good Luck
Aug 26, 2010 | Webroot AntiVirus with AntiSpyware &...
I need instructional manual for tiger wood 08 pc dvd
Tiger Woods PGA Tour 08 (IBM PC Compatible) Instructions:
COMPLETE CONTROLS
GENERAL KEYBOARD CONTROLS
Alt Key = open pop-up menu
Control Key + M Key = return to main menu
Control Key + K Key = view scorecard
Control Key + L Key = view leaderboard
Control Key + O Key = options screen
Control Key + B Key = view caddie book
Control Key + S Key = save game
Left Arrow or Right Arrow Key = aim left or right
> or < Key or Mouse Wheel = select next club
[ or ] Key = select next shot type
Esc Key = skip ball flight, cancel shot
T Key = toggle trueswing analyzer on or off
M Key = take a mulligan (if enabled)
/ Key = bring up putter
P Key = enage practice swing (once to take a swing, again to step up and address yout ball)
CAMERA CONTROLS
W, S, A, or D Key = move camera forward, backward, left or right
F or V Key = move camera up or down
- or + Key = slow or speed up camera movement
1 Key = swing view
2 Key = ball-drop view
3 Key = blimp view
4 Key = green reading view
5 Key = ball cam forward to green
6 Key = low camera to flag
7 Key = tv tower tee box view
8 Key = tv tower greenside view
9 Key = side profile swing view
0 Key = opponent view
Control Key + E Key = camera editor
E Key = shot target camera
G Key = toggle grid on or off
O Key = toggle overhead map on or off
ONLINE GAMES
Enter Key = chat
GAMEPAD SWING CONTROLS
SETTING UP A SHOT
D-Pad = move targeting mark
5 Button (Hold) + Left or Right Analog Stick = control free camera
9 Button = watch the hole fly-by overview
10 Button = preview club yardage
6 Button = switch clubs
4 Button = change camera view
1 Button = select shot type
3 Button = zoom to targeted landing spot
2 Button = start swing
SWINGING
2 or A Button + Left or Right Analog Stick Down = begin backswing
Left or Right Analog Stick Up = downswing
Left or Right Analog Stick Back Diagonally + Left or Right Analog Stick Up = draw or fade the shot
PUTTING
Left or Right Analog Stick Up and Down = putting
TRUESWING
Mouse Back = backswing
Mouse Forward = downswing, follow-through
Esc Key of Left Mouse Button = interrupt a swing
Jan 01, 2009 | Electronic Arts Tiger Woods PGA Tour 08 ...
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
D-pad and internet
wen u go on these things dont swich the power button down because it locks it from connor
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
Microsoft Windows XP Home Edition Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
