Machine runs fine on hot or warm water settings. Problem is it runs dry when set to cold water. Supply lines are OK and water valve tested as OK.
Check cold hose to see if it is clogged or the filter in the end of it is. Make sure water freely coming out from the tap. If that is all ok then replace the watter control valve on the cold side.
Hose works, not clogged, I took out the water valve and had it tested. It works fine.
I like replacing valves more than following the wires. Perhaps because I am better with a screwdriver than a circuit tester.
