Question about Maytag Microwave Ovens
My microwave quit working
I was changing the light under the microwave and it shorted out and know the microwave wont cook it makes a noise like its on but the internal light doesnt come on and the oven doesnt heat the clock and timner and all the other components seem to work but not the internal parts and when the light poped it blew a fuse in our circut breaker box
  • 108 Answers
You have obviously damaged the circuitry. Service is expensive. Unless the unit is under warrantry my advice is to replace the oven. The newer ovens are very reasonable and have great features. Check Home Depot.
Ray
Posted on Jan 01, 2009
Sharp microwave makes roaring noise light go on and off when i popped popcorn in bag help
Is it a loud growling noise and it doesn't cook? If so, it's probably a shorted high voltage diode. Secondly, it may be the magnetron. I don't think the popcorn had anything to do with this failure.
Oct 18, 2013 | Microwave Ovens
Microwave door alignment is off, will count down but won't cook
My microwave will not heat up its in a defrost mode. How do I change it?
Jul 27, 2013 | Sharp R-1505 Microwave Oven
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
PLMBZ209GCA Professional Series microwave: the timers and lights all work but NO Microwave?
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
Feb 01, 2013 | Microwave Ovens
Panel works put microwave does not heat
It is one three things, the magnetron, cracked high voltage diode, or the high voltage capacitor "sometimes shorts"
Mar 20, 2012 | Microwave Ovens
Mu accuwaave makes a short noise intermittenly while trying to heat
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Mar 24, 2011 | Whirlpool Accuwave Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
Changed bulb in whirlpool microwave model mh1150xm know it wont work, i have clock and can set timer and cooking power but when i hit start it wont come on
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too, as well as other functions.
Jan 31, 2010 | LG Over-the-Range Microwave
Microwave smells like burt wiring and does not heat
Well folks I'm parity sure you have got your money out of this unit and then sum. 16 yrs is a lot of service. Just buy your self a new one. It would not be worth buying parts for a dead unit.Good luck happy shopping DFD
Apr 13, 2009 | Whirlpool MH7140XF Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
233 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
