Question about Teac USB2 TV TUNER (USB2TVTUNER) Video Capture
No sound on TV
Hi, I've got a Teac CT-M5129STC tv that has no sound? If you get real close to the speakers you can hear sound but very faint, with volume right up. I pulled the back off and had a look for dry joints, but appart from a few warm looking patches and a bit dusty, nothing jumped out at me. Any ideas would be great thanks!
    Habit-Forming:
  • 138 Answers
Replace audio ic
Posted on Nov 17, 2017
Genius2k4
  • 27 Answers
SOURCE: NO POWER TO TV SET
I would change the fuse in the plug I see you are in australia and I do not know if your plugs are different over there, I can almost garuntee it is a fuse hope this helps
Posted on Aug 02, 2007
  • 4102 Answers
SOURCE: TEAC DC-D2800 Digital Compact Hi-Fi System
check all wires to speaker are correct also if you take the unit apart you might find that their is 2 or 3 fuses inside it might be that one of these has blown.
Also check no dust has over heated anything as this is often the case when anything electrical has been off for a while.
Let me know how you get on ok
Posted on Dec 10, 2007
  • 7 Answers
SOURCE: TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Posted on Dec 28, 2007
SOURCE: Teac AG V8050
try using an antenna.
Posted on Jan 31, 2008
jack_daniels
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
TEAC Axia TV Model: LCDV 2605 set up to use surround sound speakers. Wish to revert to TV's own built-in sound system speakers only. Do not have a manualas was gifted a second-hand TV. Help?
If you have the remote, simply go into the audio menu and check TV speakers. If you don't then you'll have to either purchase a duplicate remote or find a universal which will allow you to access the audio menu of the TV. I'm afraid there's no other way that I know of. Good luck. So, you have no sound at all on the TV as is, correct?
Jul 26, 2017 | Teac Audio Players & Recorders
No sound on tv or dvd
If its a combo (what is brand and model number???) and has a headphone jack---the jack may be the problem.
If no jack something in audio circuit is gone===place ear up close to speaker and see if you hear ANYTHING AT ALL, even a hiss or faint audio.
It is also rare but possible the speaker (if only one) is bad==easy to check with back removed.
Mar 11, 2012 | Televison & Video
Do you have a manual for a Teac TV Model CT-M5122H?
For $6.99, you can dowload it here: http://www.devicemanuals.com/support/teac-ct-m5122h-pdf-manual-310272.html
Aug 25, 2011 | Televison & Video
I have lost all sound on my tv. You can hear snapping or popping but the sound is real faint on highest setting.
I am sorry to hear about your misfortune. Unless you changed some sound settings right before that happened then the likely cause is that your tv's internal speakers have blown. Which will cause that really faint sound even when the volume is all the way up.
If your TV has an audio out connection you can try hooking it up to surround sound or a receiver with some speakers. You may be able to use your tv this way and get sound.
Otherwise you will have to make use of your warranty if the TV is still covered. If not then there is nothing more I can suggest. Repair cost might be more than hooking it up to an external sound system.
Post back if you have any further questions or comments.Thank you for choosing Fixya.
-Daniel
Oct 17, 2010 | Televison & Video
How to replace on/off power switch on TEAC CT-M343 TV
the switches have a small spring that helps click the button to stay on or off its common for the spring to snap if you have another switch just pull it appart and replace as you undo it of not you can jam the switch on with a slide of paper or match stick then turn on off at wall or put a lighting switch in line with the power cord such as from a lamp
Apr 21, 2010 | Televison & Video
How do I turn my tv sound off so I only hear the surround sound. Both are playing at the same time. Polaroid tv and Samsung surround.
get unto the settings menu by pressing menu button and go to the audio settings and change the speaker settings to external or off.
Dec 28, 2009 | Teac PLD-100V System
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Teac USB2 TV TUNER (USB2TVTUNER) Video Capture Logo
71 people viewed this question
Top Teac Televison & Video Experts
JOHN TOPLISS
Alun Cox
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
