See this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: treadmill wont run its saying waxer empty and
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
SOURCE: hi i have life fitness 9100 hr. it is not
Could be a number of reasons - first to check would be the small micro switch behind the red "stop" button. these sometimes go faulty and will reset the machine at data entry
SOURCE: Just got a used Life
this problem is due to a false in the terminals that connect with the microswitch, you must remove the screen and back-side only remove the screws and tighten the terminal could also apply contact cleaner
SOURCE: Describe your 9100 Next Generation
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
