Question about SanDisk Sansa e250 MP3 Player
The device was fully charged and I have been listening to the book off and on all day. Sansa just stopped playing, screen to black. When I open WMP and connect the USB; the WMP will not acknowledge that I even have a device connected. Tried pressing both menu and center button together for 30 seconds, then menu alone which has worked many times in the past. No go.
Make sure the lock switch is not engaged. If it is not, you may have a hardware problem which will require replacement. If none of the methods below work, call Sandisk and get your player replaced if it is still under warranty:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Dec 28, 2016 | Amazon Tablets & eReaders
Apr 23, 2013 | JVC HD-52G886 52" Rear Projection HDTV
Nov 13, 2010 | Amazon Kindle Wireless Reading Device
Jan 13, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Aug 30, 2009 | Apple iPod shuffle MP3 Player
Jul 04, 2009 | GPS
Apr 02, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Dec 18, 2008 | Audio Players & Recorders
