Question about Dell Inspiron 1525 Laptop Jet Black
No screen if led lights plugged in
Hiya thanks for your reply,i have checked my new palm rest,and it is exactly the same as my old one,all the paper,and card etc are in place,and it is still stopping the screen from working if the led lights are plugged in.have you got any other ideas please
  • mwit465
    mwit465 May 11, 2010
    Well since the palm rests have no electrical parts to interfere we have to assume something changed when you replaced them. I always try to re-trace my steps so to speak. So when you took the old ones out did you bump or detach a wire or move it over to contact another and create a short? What computer do you have, I'll check out the components and get back to you.
Trailer LED Lights follow up
check earth connection to car body had a similar experience and the earth connection to the car body was the problem on the car side of trailer socket and caused this strange behavior you are also experiecing.
Feb 05, 2015 | Televison & Video
Back light sometimes works
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 10, 2012 | Acer Aspire As5250-0327 320gb - Perfect...
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
Pavillion dv2025nr Blank Screen, but all LEDs on.
VGA card problem..that's what tech told me & changed it 3 times...but still laptop goes off.(exactly like u described)...they finally said need new motherboard??? so VGA will not do this again!!!! I don't know, If I change motherboard...will this happen again...is it worth it??? My pavillion dv 2000 is only 1.5 years old..was expensive??/
Oct 01, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen not working
Sounds like you've shorted something against this led wire. Did you maybe forget to slip that thin piece of paper or plastic back in before installing the new palm rests?
Let me know if this helps
Dec 31, 2008 | Computers & Internet
Palm Centro - no backlight
Sometimes we can resolve the issue by pressing the Options key and the Menu key simultaneously. The Centro Keyboard backlight would Turn ON.
Nov 01, 2008 | Palm Treo 500 Centro
Treo 755p screen light goes out
Found my own problem...it WAS under "settings"...under lighting, I believe. Thanks anyway.
Sep 01, 2008 | Palm Treo 755p Smartphone
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Palm Treo 680 does not power up
ive had my phone for almost 2 months now. My old treo 680 didnt even turn on... this was a replacement. Now it seems i'm having the same problem again where the phone froze and now it wont even turn on. Its really starting to piss me off now and if anyone can give any advice besides "taking out the battery" or "hard and soft resets" it would be great.
Feb 02, 2008 | Palm Treo 680 Smartphone
Dell Inspiron 1525 Laptop Jet Black  Logo
20 people viewed this question
Alun Cox
