Question about Pioneer DEH-3400 CD Player
Time Well, it's not really a problem, I just need to know how to change the time on the display pannel of the CD changer.
  • Anonymous Apr 14, 2009
    How do you change the clock display on the DEH-3400?
  • 41 Answers
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
Posted on Sep 21, 2007
My 03 PT radio is flaking out
Sounds like you need the anti-theft code. Usually when you change the ignition you have to put that code in
Apr 25, 2017 | 2003 Chrysler PT Cruiser
Need to set time on DEH1700 pioneer car cd player
Hi!
Turn the cd changer off and then press the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is set as required.
Do revert for any clarification. Thanks for using Fixya and do rate the solution if found helpful.
Thanks
Rylee
Apr 03, 2009 | Pioneer Car Audio & Video
Have a sony xplod cdx-s2000 Cd-r/rw and no manual i would like to know how to set the time so i know what time it is in the car.
press and hold the display button, the unit will beep, and the hour number will blink. press the volume up/down buttons to change the digit, press the select button, in the top left button of the faceplate to change from the hour spot to the minute spot, once the time has been set, press display again to save the time.
Feb 25, 2009 | Sony Car Audio & Video
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Dec 14, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Changer no longer reads discs
Leaving the other CD's in would not have changed things. This was just a coincidence that it happened then.
You may have a bad laser pick up, that is the most common failure for these when they won't read a disc. You can try running a lens cleaning disc thru it and see if that helps. If it doesn't help, you really need to have it serviced by a professional service center.
The laser pickk up can fail at any given time, it is kinds like a light bulb. Most of the time it works just fine right up until it fails. Nothing you can do about that. Don't blame yourself for changing the magazine. it really had nothing to do with it.
Let me know if you need any more help with this,
Dave
Jul 01, 2008 | Kenwood KDC-C465 6-Disc CD Changer
Cddj
My 2000 expedtion cd changer just stop working.The display says "NOCDDJ".Don"t know why.
Feb 09, 2008 | Car Audio & Video
07 Armada
You will need to ask the dealer to replace the display again I'm afraid. I had a friend that had a similar problem with their Nissan. They had problems with display and the CD 4 times. If you try and do it yourself, that will void the warranty. Good luck
Dec 20, 2007 | Audio Players & Recorders
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Changing the clock
Try this, which works for most Pioneer car radios, they say.
Turn key to ignition on or accessories position, turn radio off. A time should be displayed, and maybe it is incorrect.
Press the Function key and hold it for 3 seconds and the hour will flash. Use either the up/down or the left/right button to change the time. When finished, I think you push the Function key again.
Nov 08, 2007 | Pioneer DEH-235 CD Changer
Pioneer DEH-3400 CD Player Logo
243 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
