Question about Siemens Washing Machines
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
    Top Expert:
  • Siemens Master
  • 9,472 Answers
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Posted on Oct 16, 2012
    New Friend:
Disple 1E
Posted on Oct 05, 2013
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: Kenmore Elite Washing machine error codes
I am getting the code f 21 what does this mean
Posted on Jun 02, 2010
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
SOURCE: about toshiba washing machine
very simple you just press the WATER FLOW button, PRESET button and RINSE button to reset it memory test it out
Posted on Jun 19, 2010
Bosch classic washing machine has a f17 error code anyone know the fix for this?
web pages suggest that it is a water supply problem---no water coming in
check tap turned on and passing water( faulty tap washer )
check for power to water control solenoid ( solenoid failure)
check for power to solenoid ( program board problem)
call a technician for a proper diagnosis
Jan 09, 2017 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
My Hotpoint WMF540 (Aquarius) keeps displaying DOOR error message
I know this is an old question but for the benefit of anyone else having the problem, here's how I fixed it on our machine ( a WMF540 P (UK) R ).
Our clicked about 6 times then displayed the "door" error. The clicking noise is the solenoid inside the door interlock. The fact that it was clicking showed that it was functioning. Just as a precaution I removed and disassembled the interlock to check it and everything inside was fine.
Next, I removed the rear panel of the machine, took off the drive belt, disconnected the white plug and earth lead from the motor. Undid the two bolts holding the motor and dropped the motor out of the bottom of the machine.
The commutator was completely black. I removed the carbon brush holders and gave everything a blast of compressed air to get rid of the carbon dust. I then used a piece of very fine wet and dry abrasive paper and cleaned the commutator so that it was nice and shiny again. The brushes looked like they were on their last legs but as I didn't have any others available I just put them back.
After replacing the motor and the belt I tested the machine and it worked fine. Now I'll buy some spare brushes and replace them at some conveniente time in the future.
May 01, 2012 | Hotpoint Washing Machines
Anyone know what code F17 means on my HE5t washer and how to fix it
sorry no i/we dont know i have seen this question in mant various froms here this morning we all know F25 code but i and suspect everyone has no idea what the F17 means since i have seacrhed and can not find any reference to it anywhere on the various sites i use to look up Whirlpool Duet error codes...nor in my years in the fileld servicing Duets have i ever seen the F17 code
Sep 28, 2011 | Kenmore Elite HE5t Washer
F17 error, what does it mean?
My list for Siemens/Bosch states 'F17' as being 'inlet valve problem'. Sorry- service call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 13, 2011 | Siemens Washing Machines
Machine is displaying F17 have cleaned out filter still having problem with dryer not working
Hi.
F17 means that there is poor or no water inlet detected.
From user manual: F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter (see page 10 of manual). Also check water pressure is not too low.
If that does not fix the problem, then inlet valve, pressure from the house and water pressure switch must be tested. The defective part must be replaced.
Regards.
Ginko
Jun 18, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Keep getting F17 and time is locked on 15 quick wash and won,t start BOSCH CLASSIXX6 EXPRESS
E:17
  • This code indicates a leak and usually appears with the "wash" indicator light. Check the supply hose and make sure it is tightly attached to its fitting. If there is a crack in the fitting, you may need to replace the hose or the fitting or both.
Read more: Bosch Washer Error Codes ' eHow.com http://www.ehow.com/list_7190513_bosch-washer-error-codes.html#ixzz1OJs6RoB7
Jun 04, 2011 | Washing Machines
Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
Jun 27, 2009 | Bosch Washing Machines
Washing Machines Logo
7,733 people viewed this question
Top Siemens Washing Machines Experts
Marvin
Marvin
Mike
jimorris77
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
