Question about Mintek DTV-263 26 in. LCD Television
The screen says Air, No signal the channels will not change on tv or remote DTV 265-D with built in DVD
  • Steve Allison
    Steve Allison May 11, 2010
    How do you get your signal?
    That 'Air' means antenna reception other than cable or satellite.
    It may just be looking at the wrong input.
    If you have cable; select that from your TV's menu
    If you have satellite, select that.
  • 362 Answers
Do you have an anntenna connected to the tv?  if so go to the menu and do Auto Channell Search. If you do not have a anntenna and have a cable or sattilite box you need to change the tuning band from air to cable.
I can assist further if needed.
Posted on Jan 08, 2009
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
Mintek DTV-265-D I have a Mintek DTV-265-D, the
To change source you have to press repeatedly the Video button on the original remote:
Here the manual.
If you have lost the original remote, you can find a replacement here:Mintek DTV265D Replacement Remote Control.
Oct 26, 2010 | Mintek DTV-265-D 26 in. LCD TV
Mintek remote will not change channels. Tried a
See if you can change channels by manually punching them in on your remote. If so, you need to go to your menu, channels and autoscan your channels again. Then you should be able to use your forward and backward buttons again.
Nov 29, 2009 | Mintek DTV-265-D 26 in. LCD TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Air Digital No signal on the screen. Cannot change channels
hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Dec 26, 2008 | Mintek DTV-263 26 in. LCD Television
TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Feb 20, 2008 | Televison & Video
Mintek 26 inch LCD HDTV with built-in-DVD remote not working
The reason you can't pull-up the Mintek website is because the company is out of business. I have one that is frozen on one channel and none of the buttons or remote will work. I took it to a repair shop and the said one of the circuit boards is bad but since the company is out of business they can't get the needed part. The only way to get the part is to find a set which can be cannabalized for the needed parts.
Feb 10, 2008 | Televison & Video
Mintek 26" lcd hdtv dtv 265-d
Oct 09, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-263 26 in. LCD Television Logo
78 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
