Question about Epson Office Equipment & Supplies
My ink cartridge will not work
I have added A new ink cartridge but the rest of them are empty why will it not allow me to print with that color
    Problem Solver:
  • 12 Answers
If it is an HP or Brother the printer will only work with full cartridges both color and black. You must have ink in all cartridges
Posted on Dec 31, 2008
  • kdreis Jan 01, 2009
    The solution relates to all printers that use ink
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Hello. How do you clean the cartridge as it is a little dried up for printer HP PSC 1210 all in one printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
The best solution for you is to buy some isopropyl alcohol from chemist, which is a great solvent for dried ink, and drop 8-10 drops into the ink nozzle, put it back in and try running a few prints then repeat the process. If it doesn't help, you will be better off buying new ink cartridges.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I have a Brother MFC 790cw that does not print black all the other colors work, I have updated the driver bought a new ink cartrige and used the the clean option for the black ink. I know it is recieving...
Try printing a rest page and if that doesn't print in black ink the printhead is probably blocked.
With some printers the printhead is part of the ink cartridge and such problems tend to disappear when the cartridge is replaced, unless the cartridge is faulty. Other printers use cartridges that are ink and nothing more and those are prone to the printheads drying out and becoming blocked unless they are never allowed to become completely empty of ink and are kept in frequent use.
Cleaning/replacing such a printhead usually needs special tools and experience and in the case of many cheap domestic printers the cost of service far outweighs the cost of replacement.
Aug 13, 2017 | Brother MFC790cw All-In-One InkJet Printer
Added new ink cartridge and now it says its empty
Check
1.) Were the cartridges compatible ?
2.) are they correctly installed.
try taking them out & reloading.. this should fix it .. provided teh cartridges are fine.
Thanks
Fame !
Apr 27, 2009 | Dell 926 All-In-One InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
I have a cannon MP160 printer. Color ink button is flashing. The color ink cartridge is empty. I replaced the black ink cartridge and want to print in blank ink only. However, I can't get the color light...
try to go into the software for the printer and find a rest ink cartridge button. This will make it think it has a new one which wil let you print in black by selecting black print only
Jan 08, 2009 | Office Equipment & Supplies
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
