Question about Amana NDE2335AY Electric Dryer
Dryer stumbles to get started spinning
Admiral Designer Series dryer Giant Capacity Plus LNC7757A71
Start up the machine, and the barrel stumbles to spin, and then is loud when it spins
  • telismen Jan 03, 2009
    haven't had a chance to open it up, but will check it soon
  • Amana Master
  • 8,220 Answers
Probably need the wheels and idler inspected
Posted on Jan 01, 2009
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Dryer will not work. Makes buzzing sound when
locked up dryer motor,replace-mike
Jul 17, 2009 | Dryers
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1737&PPStack=1
Nov 21, 2008 | Dryers
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Amana NDE2335AY Electric Dryer Logo
366 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
